Which map? (98 T595) Details inside.
Bike has a "modified" airbox (looks broken, has a hole in it, snorkels removed), K&N filter, wunoff undertail exhaust, vin ending in 060323, build date 11/97.
Previous owner claimed it had "upgraded cams" which I suspect the original owner told him it had the update exhaust cam as it appears to have new vacuum lines and the starter even looks newish compared to the oily, grimy, patina of the rest of the block (fingers crossed for that one eh?).
If I'm reading the tune list correctly and the PO/OO is full of excrement and it's all original I should be running 9860Map. And if it does have the updated cam maybe 9863Map?
Bike does have a cam sensor, that was connected when I started pulling things apart, and the rear speed sensor. I would prefer to remove anything the bike doesn't need and/or wont use.
I'll be cracking the valve cover to do a valve check, are there any markings on the exhaust cam I can look for to determine if it does have the updated cam?
