tuneECU fuel gauge problem - Triumph Forum: Triumph Rat Motorcycle Forums
ECM and FI Tuning - Help, Tips & Tricks We invite members from across TriumphRat.net to post your questions, or share your expertise or experiences on TuneBoy, TuneECU and PowerCommander (etc).
Closed Thread
Old 11-18-2012, 10:40 PM   #1 (permalink)
Main Motorcycle: 2002 Daytona 955i
tuneECU fuel gauge problem -02 D955i
Forgive me for asking but i havent really seen a clear response for this problem.
A few weeks ago my check engine light came on again. I assumed it would go away like before but it remained. The low fuel light would came on and off several times after filling up. Looked like my fuel level sensor was acting up. I finally got my tuneECU up and running and pulled the errors. It yielded
P0135 - oxygen circuit malfunction
P0353 - ignition coil 3 circuit malfunction
P1353 - ignition coil 3 open circuit or short circuit to battery
P1351 - ignition coil 1 open circuit or short circuit to battery
P0230 - fuel pump to relay default
P1231 - fuel pump relay open circuit or short ground
P0460 - fuel level sensor malfunction
I know the fuel pump is functioning properly. Only error code that seemed to make sense was the fuel level error. So I cleared those and immediately the next day on my way to work the CEL came back on. Pulled it again that night and only gave me the code
P0463 - fuel sensor circuit high input
Which again makes sense. I read somewhere (on here on the threat I cannot relocate) that "it is better to fix the sensor than replace it with an OEM one" -deano. Has anyone written a DIY for just this thing cause if so I haven't found it?
mesablu is offline
Old 11-19-2012, 07:09 PM   #2 (permalink)
I reported this in Daytona deliberations
mesablu is offline
Old 11-19-2012, 08:06 PM   #3 (permalink)
Legend
DEcosse's Avatar
it was answered there
This is not a TuneECU issue - use the model forum to discuss actual problems, this is for tuning related Q & A
DEcosse is online now
Closed Thread
fuel level gauge showing random fuel levels DesmoBanana Sprint Forum 6 06-07-2011 08:00 AM
Fuel gauge problem after TOR re-map caddydaddy Sprint Forum 6 07-21-2008 09:03 AM
fuel gauge problem in the 07 tiger tman11535 Tiger Workshop (archive) 3 06-30-2007 05:11 PM
Wher do I go to complain about the fuel gauge problem? tman11535 Tiger Chat 4 06-17-2007 09:32 PM
Fuel Gauge Low Fuel Light problem any ideas ? CYNCRZR Sprint Forum 4 06-09-2007 11:36 PM
