IMPORTANT NOTE for TuneECU User re Triumph Anti-Tamper Policy - Triumph Forum: Triumph Rat Motorcycle Forums
ECM and FI Tuning - Help, Tips & Tricks We invite members from across TriumphRat.net to post your questions, or share your expertise or experiences on TuneBoy, TuneECU and PowerCommander (etc).
 2Likes
post #1 of 78 (permalink) Old 11-18-2012, 12:07 PM Thread Starter
Main Motorcycle: Triumph Speed Triple 1050
Tom_Hamburg's Avatar
Other Motorcycle: Triumph Rocket Roadster
14-November-2012- IMPORTANT NOTE:
Attention !! The following models are factory equipped with an anti-tamper system:
  • Triumph Tiger Explorer, all models
  • new Triumph Trophy, all models
  • new Triumph Street Triple from model 2013 and upwards
Never connect TuneECU with these models
BR, Tom
Tom_Hamburg is offline
post #2 of 78 (permalink) Old 11-18-2012, 03:53 PM
Main Motorcycle: None at this time
The Bonneville is safe for another year.
biker222 is offline
post #3 of 78 (permalink) Old 11-18-2012, 10:57 PM
Main Motorcycle: 2010 Rocket 3 Touring
Tripps's Avatar
Other Motorcycle: TT600,Sprintona, K1200GT
Extra Motorcycle: BMW r65/sidecar, CBR1000
Seems crazy, I wouldn't buy a bike I couldn't retune, since I discovered Tune ECU. If they go that way with all models, I won't be buying any new Triumphs.
The greatest obstacle to discovery is not ignorance -- it is the illusion of knowledge. - Daniel J Boorstin
Carpenter Racing 2010 Touring 241 hp, 185 ft lbs
Tripps is offline
post #4 of 78 (permalink) Old 11-19-2012, 11:57 AM Thread Starter
For Bonneville models up to 2012, yes.
For the model from 2013 is not yet known.
BR, Tom
post #5 of 78 (permalink) Old 11-19-2012, 12:22 PM
All the new feature means is that for all intents and purposes, the Triumph ECU will be tamperproof as far as TuneECU/Tuneboy is concerned. I presume this was added to protect the manufacturer in terms of its warranty.
While it is unfortunate, all that this will do will be to place all new Triumph owners in the same situation as Yamaha, Honda, Kawasaki , Suzuki, and I would even think HD owners! As with all these marques (and others?), the new Triumph lock-out feature will not prevent the use of a Power Commander and other aftermarket fueling/ignition module add-ons. Indeed, an earlier factory instruction seemed to allow for these modules to be added in terms of their warranty. I am presuming that this is still the case? In any case, their use will not cause the ECU to shut down and only be re-operable by direct intervention of the factory.
DeanRider is offline
post #6 of 78 (permalink) Old 11-19-2012, 12:50 PM Thread Starter
But I'm pretty sure that even this protection will be cracked eventually. Only when that will be is written in the stars.
BR, Tom
widegld likes this.
post #7 of 78 (permalink) Old 11-19-2012, 09:10 PM
DEcosse's Avatar
Can you clarify Tom - does it simply not work, or work but records that the Tune has been modified, thereby invalidating potential engine warranty claims?
DEcosse is online now
post #8 of 78 (permalink) Old 11-20-2012, 01:53 AM
Forchetto's Avatar
I've read the Factory's statement over and over again and it seems to say that the ECU will somehow record the use of a non-approved map and snitch on you...
The third paragraph of the original notice seems to say so:
Forchetto is offline
post #9 of 78 (permalink) Old 11-20-2012, 04:29 AM
I suspect that the security could simply be a checksum match or non-match of authorized tunes. Whether a non-match would trigger more than just the stated logging ... Like an operation shutdown or lockout is the question. If it is just logging of modified tunes then that won't hinder unless you want a warranty.
Cheers, Richard
'09 America
Dunamis is offline
post #10 of 78 (permalink) Old 11-20-2012, 12:15 PM Thread Starter
The document is known, only it makes no exact information about what happens, except for the log function,
when you load with an unauthorized tool, something to the ECU (ECM / CDI).
Neither DTC (P1604: ECM tamper detected - return to Triumph), nor the constantly lit MIL is mentioned.
Also information missing, if only the diagnosis function is used by a non-Triumph tool. E.G. the dealer tool, which is used in many workshops.
Or have I overlooked something?
BR, Tom
TuneECU user questions Rayzor61 ECM and FI Tuning - Help, Tips & Tricks 7 09-28-2012 06:06 PM
Very short note on Triumph at the Paris Show ohiorider Air Cooled Twins Talk 13 12-20-2007 02:29 AM
Open Note to Triumph UK NHScrambler Air Cooled Twins Talk 16 11-03-2007 12:22 AM
A quick note on Triumph Paint Codes CYNCRZR Club Cafe' 2 11-16-2005 10:45 AM
