Tune ECU and cable drivers - Triumph Forum: Triumph Rat Motorcycle Forums
ECM and FI Tuning - Help, Tips & Tricks We invite members from across TriumphRat.net to post your questions, or share your expertise or experiences on TuneBoy, TuneECU and PowerCommander (etc).
post #1 of 10 (permalink) Old 11-08-2012, 12:03 AM Thread Starter
Main Motorcycle: 2008 Sprint ST
toonyank's Avatar
Other Motorcycle: Ex 2003 SPEED TRIPLE
2003 Speed Triple,
Well I downloaded TuneECU and I bought a cable. I inadvertently plugged the cable in and let windows find the driver (mistake) so I went to the Tune ECU site and downloaded the 64 bit driver package. Thing is I can't for the life of me work out how to uninstall the windows driver so I can re install the correct ones now.
Any clues? Need a windows 7 guru me thinks
toonyank is offline
post #2 of 10 (permalink) Old 11-08-2012, 12:18 AM Thread Starter
toonyank's Avatar
I'm looking at the Tune ECU sticky thread now
toonyank is offline
post #3 of 10 (permalink) Old 11-08-2012, 12:19 AM
Main Motorcycle: 2012 Speed Triple
SavageSS's Avatar
Other Motorcycle: Modified DRZ 470e
Right click My Computer > Manage
Click on Device Manager
Then under USB-Controller, expand this
Look for USB Serial converter, double click this
New windo will pop up, click on the drivers tab
Click Uninstall
I'm doing this from memory but should be right.
Otherwise do a system restore
Right Click My Computer > Properties
Click System Protection Tab
Click System Restore
Choose your restore point
Then next and OK.
It will roll back and reboot the computer.
Again this is from memory..
Good Luck
SavageSS is offline
post #4 of 10 (permalink) Old 11-08-2012, 12:21 AM
Main Motorcycle: 2009 Street Triple R
t3ckfr3ak's Avatar
Extra Motorcycle: 1978 XS400 Yamaha
I can't believe you would recommend anyone use system restore, don't do that
Sent from my Desire HD using Motorcycle.com App
2009 Street Triple 675 R
12,000 miles and some-days it still scares me.
t3ckfr3ak is offline
post #5 of 10 (permalink) Old 11-08-2012, 12:25 AM Thread Starter
toonyank's Avatar
I'm not sure I'll have to use restore but I've done that before. If you know a good restore point it's no problem. Thing is I have the cable plugged in and I don't see a USB serial converter. The light on the cable is on so it recognizes it.
toonyank is offline
post #6 of 10 (permalink) Old 11-08-2012, 12:28 AM
Main Motorcycle: 2007 bonnie black
killian101's Avatar
Other Motorcycle: 68 BSA (RIP)
Extra Motorcycle: 2015 Daytona
Yeah, don't do a system restore... no need to. Go into device manager (use Google if I can't find it). Find the USB device, right click on it and uninstall device. Also, Google, uninstall USB device win7
Sent from my SGH-I747 using Motorcycle.com Free App
killian101 is offline
post #7 of 10 (permalink) Old 11-08-2012, 12:35 AM Thread Starter
toonyank's Avatar
Well that's the thing. In the device manager I can't see the device even when I show hidden devices. I'm trying to insert a screen shot but I'm stuck
toonyank is offline
post #8 of 10 (permalink) Old 11-08-2012, 12:56 AM
SavageSS's Avatar
System restore. Why not?
Apart from saying not to recomend it why?
When I use to be a computer tech, this was by far easiest and quickest way to help if you were or the user was unsure of what they did and something was broken. Either spend x amount of time trying to fix it, or roll back to a known good.
Especially in the case of the situation the OP is in, spend more time trying to look for the driver or be done with it, and system restores (as long as there's a restore point)
I still stand by it.
SavageSS is offline
post #9 of 10 (permalink) Old 11-08-2012, 01:05 AM Thread Starter
toonyank's Avatar
Yeah me too M8. I've used it before successfully. It's my works laptop so I'm just a bit cautious. I'll figure it out I'm sure.
toonyank is offline
post #10 of 10 (permalink) Old 11-08-2012, 08:27 AM
SavageSS's Avatar
Good luck.
Being a work computer you may not have admin rights which may prevent you from doing this.
If so, it could also explain why you can find it installed. Most drivers / apps need to install in to the registry in HKEY_LOCAL_MACHINE which needs admin rights, some install into HKEY_CURRENT_USER which doesn't need admin rights..
Is it possible it never installed correctly, if you are familiar with the even log it should tell you there.
SavageSS is offline
Triumph Twin Power USB Cable and XP Drivers Carlcampion Air Cooled Twins Technical Talk 5 10-24-2012 08:26 PM
OBD2 cable drivers???? David L. ECM and FI Tuning - Help, Tips & Tricks 22 10-22-2012 10:54 AM
Drivers for ECU cable eigenvector Tiger 1050 - Mods & Workshop 4 03-01-2012 12:41 PM
Tune ECU cable LetsGoOilers Daytona Deliberations 3 05-18-2011 05:46 PM
TuneECU cable...should i use the enclosed drivers.... dazco ECM and FI Tuning - Help, Tips & Tricks 4 09-19-2010 04:10 PM
