Printing fuel map - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
ECM and FI Tuning - Help, Tips & Tricks We invite members from across TriumphRat.net to post your questions, or share your expertise or experiences on TuneBoy, TuneECU and PowerCommander (etc).
Old 11-03-2012, 06:34 PM   #1 (permalink)
Main Motorcycle: Triumph Sprint 2006
Other Motorcycle: Ducati 900SS 1993
Printing fuel map
in Tune ecu is there any way to print the fuel map?
Thanks.
matjen is offline   Reply With Quote
Old 11-03-2012, 08:03 PM   #2 (permalink)
Main Motorcycle: 2006 Sprint ST ABS
champ87's Avatar
Extra Motorcycle: 1973 Yamaha RD350
If you want a graphic the just hit the Print Screen button on your computer then paste the image into a graphics program and print from there.
For a simple table of the values use Edit>Export Table to save data in a .txt file. You can open the file with Notepad to see a table of values without any fancy formatting.
You can also open the .txt file with MS Excel. Open it as a tab-delimited file and you'll have a table of values that can be edited, formated or printed.
Champ87
It's amazing how fast you can go when you take your time.
champ87 is offline   Reply With Quote
Old 11-04-2012, 08:01 AM   #3 (permalink)
Thankyou.
3d printing varangian Classic, Vintage & Veteran 9 04-15-2012 10:24 PM
Printing in the UK. Demonic Biker Hang-Out 29 10-17-2011 06:13 AM
URGENT PLEASE: 08-09 Fuel Tank on a 07??? Fuel Pump Assembly Problems/Compatibility Sweatypants Speed Triple Forum 4 10-02-2010 12:09 AM
Quick-Disconnect Fuel Fittings and Rear Hinged Fuel Tank dealsgapdragon Maintenance & Workshop Talk 0 04-05-2009 12:42 PM
Sprint ST Fuel Line Question (fuel tank to/from fuel rail) Sprint Forum 7 01-26-2005 09:23 AM
