ECM and FI Tuning - Help, Tips & TricksWe invite members from across TriumphRat.net to post your questions, or share your expertise or experiences on TuneBoy, TuneECU and PowerCommander (etc).
Hi there.
My brother in law has a TT600.
We're looking for some ecu maps for after market exhaust.
Does any one has any different from the stock one?
Which do you recommend for power and speed as well as torque maximization?
weel guys...
today I tried to run a diagnosis on the TT and nothing...it desconects and doesn't connect again.
Once you have the bike just with the ignition on, I can read, load maps, make the tests.
Then I reset TPS, disconnect the ignition, turn the ignition once again, start the bike then try to connect the tuneecu, its connects, takes long to connect, then I start the diagnosis and a few seconds later, the connection fall down.
Is there any explanation for this?
Yes, it was low voltage battery.
Now its perfect, idling perfect and running spectacular with the PC tables.
I wonder if there are other tables or maps for this model????
So few...
