TuneECU For Dummies -Installation Guide and Questions pertaining to Installation - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
ECM and FI Tuning - Help, Tips & Tricks We invite members from across TriumphRat.net to post your questions, or share your expertise or experiences on TuneBoy, TuneECU and PowerCommander (etc).
 13Likes
post #11 of 310 (permalink) Old 10-06-2012, 09:57 PM
Main Motorcycle: 2011 Bonneville SE
Thanks for sharing..big help for a newb!
Catmando is offline
post #12 of 310 (permalink) Old 10-07-2012, 11:37 AM
Main Motorcycle: Triumph Speed Triple 1050
Tom_Hamburg's Avatar
Other Motorcycle: Triumph Rocket Roadster
Originally Posted by davebullet View Post
Excellent! May I add the following which I wrote when I accidentally didn't disconnect from the ECU and the bike wouldn't start. It's a real step by step instruction to download a new map to your ECU
These instructions were used on a 2010 NJ2 Speed Triple 1050.
Hi,
I have this little guide, transferred in a slightly altered form, in our online manual.
Thank you for this step by step guide.
BR, Tom
Tom_Hamburg is offline
post #13 of 310 (permalink) Old 10-07-2012, 01:54 PM Thread Starter
Main Motorcycle: 2007 Triumph Speed Triple
Ebster1085's Avatar
Send a message via AIM to Ebster1085
Originally Posted by Tom_Hamburg View Post
Hi,
BR, Tom
Awesome! Glad you approve!
You're welcome to everyone who has thanked me. Glad the little bit of work I put into this has gone a long way to help others.
LSL Damper OES Sliders Sunline Shifter MIVV CF Slip On K&N Air Filter FH012AA R/R Stoltec Starter Cables The2Wheels Levers Rick's Hotshot Stator Samco Hoses RK Chain & Sprockets
Ebster1085 is offline
post #14 of 310 (permalink) Old 10-27-2012, 12:46 PM Thread Starter
Ebster1085's Avatar
Should we make this a sticky?
post #15 of 310 (permalink) Old 10-31-2012, 03:34 AM
Main Motorcycle: 2005 Daytona 955i
PaulM's Avatar
Hi Ebster, Don't now about this thread being a sticky. But you certainly helped me when I used Tune ecu for the first time a few weeks ago. I printed your post post and used it as a guide when I loaded Tune ecu and downloaded several different maps to experiment with. No problems whatsoever this was the first time I have tried anything like this.
Thanks Paul
PaulM is offline
post #16 of 310 (permalink) Old 10-31-2012, 09:44 AM Thread Starter
Ebster1085's Avatar
Thanks Paul
Good stuff, glad I was able to help Paul.
I just feel it makese sense to have a fairly straight forward user guide in the EFI tuning sticky section, but maybe others would disagree.
post #17 of 310 (permalink) Old 11-03-2012, 01:25 AM
Main Motorcycle: 05 Honda VFR Interceptor
UnklFungus's Avatar
Hey Ebster,
For what it's worth, on my 2000 RS, I don't have to click anything for the map to take and the 12 minute idle thing would just waste gas as the old style F.I. that I have doesn't have this feature. I just wanted to add this to save those with older bikes some gas money.
I simply remove the headlight fuses on my bike, 1 and 9 and then plug in and upload the new map in. Simple fast process. Takes longer to R&R the fuses than to change the tune.
I can upload a tune, disconnect my laptop and then head out after repalcing the fuses and seat and tell right away that it has taken effect.
Still, I am glad you have taken the time to write it up. Thank you!
Videat veritatem
See the truth
UnklFungus is offline
post #18 of 310 (permalink) Old 11-03-2012, 10:04 AM
Hi,
The data amount of Sagem-files is significantly lower than the data amount of Keihin-files. A Keihin-file contains about four times the amount of data. For this reason, it takes significantly longer, a Keihin-file to load on the ECU .
BR, Tom
post #19 of 310 (permalink) Old 11-03-2012, 02:30 PM
DEcosse's Avatar
.... I simply remove the headlight fuses on my bike, 1 and 9 ...
Only Fuse 9 should be necessary on your model - although Fuse 1 feeds the relays, those relays will be inactive anyway with the Fuse 9 removed, isolating the power from the coils as well as the direct power to the non-relay headlight.
So save yourself a further 2 secs!
DEcosse is online now
post #20 of 310 (permalink) Old 12-14-2012, 06:53 PM
Main Motorcycle: 2011 S3
I just did the install today on my Win 7 64 bit system. Without your help I would have been lost as mine did not auto start.
Thank, you da man
Jerry Holland
Man, you were haulin ass the other day when I passed you.
cognosticator is offline
Oversize valve guide installation 1943MB Classic, Vintage & Veteran 4 04-07-2014 11:58 PM
Rizoma Zero turn signals installation for the dummies? Max_NYC Speed Triple Forum 19 05-29-2011 08:10 PM
Exhaust Installation Guide? Existence_Inc Air Cooled Twins Technical Talk 4 04-07-2010 11:14 PM
Film a R&G Installation Guide? Tattoed Red Head Sprint Forum 0 01-18-2009 09:12 PM
Which ARK? And the Installation Guide? rstover Air Cooled Twins Technical Talk 10 03-13-2007 10:24 PM
