| ECM and FI Tuning - Help, Tips & Tricks We invite members from across TriumphRat.net to post your questions, or share your expertise or experiences on TuneBoy, TuneECU and PowerCommander (etc). |
10-06-2012, 08:57 PM
#11 (permalink)
Grand Prix 125 Main Motorcycle: 2011 Bonneville SE
Thanks for sharing..big help for a newb!
10-07-2012, 10:37 AM
#12 (permalink)
Formula Extreme Main Motorcycle: Triumph Speed Triple 1050
Posts: 582 Other Motorcycle: Triumph Rocket Roadster
Originally Posted by davebullet
Excellent! May I add the following which I wrote when I accidentally didn't disconnect from the ECU and the bike wouldn't start. It's a real step by step instruction to download a new map to your ECU
These instructions were used on a 2010 NJ2 Speed Triple 1050.
Hi,
I have this little guide, transferred in a slightly altered form, in our online manual.
Thank you for this step by step guide.
BR, Tom
10-07-2012, 12:54 PM
#13 (permalink)
Powerbike Main Motorcycle: 2007 Triumph Speed Triple
Originally Posted by Tom_Hamburg
Hi,
BR, Tom
Awesome! Glad you approve!
You're welcome to everyone who has thanked me. Glad the little bit of work I put into this has gone a long way to help others.
LSL Damper CRG Mirrors OES Sliders CF Frame Covers CF Heel Plates CF Tank Pad CF Rear Hugger Sunline Shifter LED FE Kit MIVV CF Slip On TuneECU K&N Air Filter FH012AA R/R Stoltec Starter Cables The2Wheels Levers Rick's Hotshot Stator
10-27-2012, 11:46 AM
#14 (permalink)
Should we make this a sticky?
10-31-2012, 02:34 AM
#15 (permalink)
Supersport 600 Main Motorcycle: 02 Sprintona ST
Posts: 171 Other Motorcycle: 03 Daytona 955i
Hi Ebster, Don't now about this thread being a sticky. But you certainly helped me when I used Tune ecu for the first time a few weeks ago. I printed your post post and used it as a guide when I loaded Tune ecu and downloaded several different maps to experiment with. No problems whatsoever this was the first time I have tried anything like this.
Thanks Paul
10-31-2012, 08:44 AM
#16 (permalink)
Thanks Paul
Good stuff, glad I was able to help Paul.
I just feel it makese sense to have a fairly straight forward user guide in the EFI tuning sticky section, but maybe others would disagree.
11-03-2012, 12:25 AM
#17 (permalink)
World SuperBike Main Motorcycle: 2000 Triumph Sprint RS
Posts: 2,012 Other Motorcycle: 05 Honda VFR Interceptor Extra Motorcycle: 1980 Yamaha IT125
Hey Ebster,
For what it's worth, on my 2000 RS, I don't have to click anything for the map to take and the 12 minute idle thing would just waste gas as the old style F.I. that I have doesn't have this feature. I just wanted to add this to save those with older bikes some gas money.
I simply remove the headlight fuses on my bike, 1 and 9 and then plug in and upload the new map in. Simple fast process. Takes longer to R&R the fuses than to change the tune.
I can upload a tune, disconnect my laptop and then head out after repalcing the fuses and seat and tell right away that it has taken effect.
Still, I am glad you have taken the time to write it up. Thank you!
Videat veritatem
See the truth
11-03-2012, 09:04 AM
#18 (permalink)
Hi,
The data amount of Sagem-files is significantly lower than the data amount of Keihin-files. A Keihin-file contains about four times the amount of data. For this reason, it takes significantly longer, a Keihin-file to load on the ECU .
BR, Tom
11-03-2012, 01:30 PM
#19 (permalink)
Site Supporter Legend Main Motorcycle: Custom 955 Speed-Tona
Posts: 13,250 Other Motorcycle: Suzuki SV650S
.... I simply remove the headlight fuses on my bike, 1 and 9 ...
Only Fuse 9 should be necessary on your model - although Fuse 1 feeds the relays, those relays will be inactive anyway with the Fuse 9 removed, isolating the power from the coils as well as the direct power to the non-relay headlight.
So save yourself a further 2 secs!
12-14-2012, 05:53 PM
#20 (permalink)
Supersport 600 Main Motorcycle: 2011 S3
I just did the install today on my Win 7 64 bit system. Without your help I would have been lost as mine did not auto start.
Thank, you da man
Jerry Holland
Man, you were haulin ass the other day when I passed you.
