We've seen a couple of threads recently where a map download has crashed part-way through and appears irrecoverable
A strong caution on taking a careful look at what cable you have purchased - there are many clones out there, built with low-cost chip-sets and not genuine FTDI
I have made this point before about how it's not how they LOOK it's what they ARE inside!
Take this one for example:
[ame]http://www.amazon.com/OBD2-Diagnostic-Cable-KKL409-1-VAG-COM/dp/B002WIN8VQ/ref=pd_sim_e_5[/ame]
It actually looks (outwardly) identical to one I have used personally.
If you read the reviews you will find several Triumph users who said it worked for them and were actually very happy.
HOWEVER you will also find these reviews -
Here's how you can validate, courtesy of Tom Hamburg
You can also use this Utility USBView (download link directly from FTDI website)
What I would suggest to all, is that BEFORE you attempt to DOWNLOAD (your cable may appear to be working just fine in Diagnostic), verify that you indeed have a genuine FTDI Chipset in your cable.
ORTom Hamburg said:
