Tune ECU ..Thunderbird problems - Triumph Forum: Triumph Rat Motorcycle Forums
ECM and FI Tuning - Help, Tips & Tricks We invite members from across TriumphRat.net to post your questions, or share your expertise or experiences on TuneBoy, TuneECU and PowerCommander (etc).
post #1 of 2 (permalink) Old 05-17-2011, 08:20 PM Thread Starter
Managed to get my hands on the cable and installation was perfect..
Connected cable and the Tune ECU found the ECU number with no problems.
Map is named 20360 (which was the Triumph tune that we started with before modifying with Tuneboy.
Went across the top bar to ECU..then…Read Map…then … comes up with a box that states Map 20360 installed …hit read….comes up with a smaller box that states Unknow (Without the n on the end) Map Type.
Shut it all down and tried again and the same results appeared .
Looks like Tune ECU will not read maps that are fitted if they have been modified by Tuneboy.
Can the tune be changed to a hex file somehow??
Hope you may be able to assist with the next step.
Cheers.
Steve
stevewal is offline
post #2 of 2 (permalink) Old 05-18-2011, 06:03 AM
Main Motorcycle: Triumph Speed Triple 1050
Tom_Hamburg's Avatar
Other Motorcycle: Triumph Rocket Roadster
Hi Steve,
This is correct and there is no way this dat-file in hex ​​convert.
The last versions Tuneboy/TuneEdit change the checksum of the map, so it can TuneECU not read this map.
BR, Tom
Tom_Hamburg is offline
Akrapovic exhaust on 01 speed triple Tune problems geared ECM and FI Tuning - Help, Tips & Tricks 3 10-13-2010 12:33 PM
problems loading first tune with tuneboy spdtriprdr888 Speed Triple Forum 7 04-10-2009 03:27 PM
TORS Tune Map Problems DeanRider Speed Triple Forum 13 01-13-2007 02:07 PM
05 ST: Problems with Offroad tune? FishHuntRide Sprint Forum 2 06-03-2005 10:28 AM
Tune problems OldSwede Sprint Forum 5 09-29-2004 01:04 PM
