Recovering Tune - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
ECM and FI Tuning - Help, Tips & Tricks We invite members from across TriumphRat.net to post your questions, or share your expertise or experiences on TuneBoy, TuneECU and PowerCommander (etc).
Old 11-07-2009, 11:55 PM   #1 (permalink)
Favourite Bike: 2010 R3 Roadster
fat frank's Avatar
Recovering Tune
just had my bike set up with Tuneboy. They put in a 2 into 2 tune with mods for my bike. I want to start playing with the timing, but am afraid to lose the tune. can I pull this tune out and save it on my bike. I didn't get a copy of the tune from the dyno shop.
I'd like to be able to edit this tune and go back to the modified tune if i don't like the results.
Thanks in advance.
fat frank is offline   Reply With Quote
Old 11-08-2009, 03:48 AM   #2 (permalink)
DEcosse's Avatar
You cannot retrieve the current file in a format you can use.
What you have to do is take a back-up copy - 'Tools'; 'Backup ECU Contents' then save under a filename_of_your_choice.tbk
You need to send that file to Wayne at Tuneboy to convert that back to your custom tune file that you can save for reference &/or modify further as you choose.
See page 18 of the tunedit.pdf application notes file.
T'Rat.net BOTM November 2009
Old 11-08-2009, 11:42 AM   #3 (permalink)
DEcosse is correct.
From now on, try to remember to take a thumb drive to the shop when dyno tuning. Or have them email it to you. The shop should have saved it when done.
Power-Tripp is offline   Reply With Quote
Old 11-08-2009, 07:02 PM   #4 (permalink)
fat frank's Avatar
Thanks for the tip. Using a flash drive would gie me what I want. thanks again
Old 11-10-2009, 09:41 PM   #5 (permalink)
fat frank's Avatar
Help Me PT
Originally Posted by Power-Tripp View Post
DEcosse is correct.
Ok, if I understand now, I can't retrieve the tune from my ecu. I can load another which will negate the one that's installed. The way to save the tune is to edit on the computer, saving the file and then to download to the ecu, make the next change, save on file and download again. Basically, I'm writing the tune, making changes, saving it on file and downloading to the ecu. Am I correct so far?
Thanks in advance
Frank
Old 11-11-2009, 02:47 AM   #6 (permalink)
Favourite Bike: Speed3 -09
Martin_R's Avatar
Yes, that is the usual way of doing things.
If you really need some tune off your bike, you will have to go the backup+email to TuneBoy route 'Tripp described.
Martin_R is online now   Reply With Quote
Tune Boy Full Arrow Exhaust Dyno Tune OUsooner Street Triple Forum 6 09-25-2009 01:19 AM
TORS tune from dealer or Tuneboy tune? Max_NYC Speed Triple Forum 25 07-06-2007 11:22 PM
Corbin seat recovering (pics) whodkne Speed Triple Forum 3 05-26-2007 03:31 AM
Bad News - Still Recovering Ridge Biker Hang-Out 15 04-13-2007 04:24 AM
Seat Recovering quagmire Classic, Vintage & Veteran 5 08-07-2005 10:20 PM
