09 Bonnie Question - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismHonda Powersports Motorcycle.comSportbikeTrackGear
ECM and FI Tuning - Help, Tips & Tricks We invite members from across TriumphRat.net to post your questions, or share your expertise or experiences on TuneBoy, TuneECU and PowerCommander (etc).
Old 09-12-2009, 08:10 AM   #1 (permalink)
Favourite Bike: 2010 R3 Roadster
fat frank's Avatar
09 Bonnie Question
I have the TPUSA 904 HP package and the 813 cams. I had to go to a PCMIII to get the AF right. She's running great and pulls hard.
I want to ditch the PC and get a tuneboy installed. Being a little computer ignorant, I'm kind of leary of the TB. They don't make a tune that would be close to what I need. Can you set the AF without putting her back on the dyno first, just to get her running right before you go to the dyno?
Also, with the PCIII, I bypassed and removed the O2 sensors. Do they have to be reinstalled with the Tuneboy?
I can't find a tuning center in Houston, Texas who works with TB. There web site has pulled there list of tuning locations. Any help here would be apreciated. I'ls like to see them and discuss the advantages of it before I go this route. Any help would be apreciated.
Thanks in advance.
fat frank is offline   Reply With Quote
Old 09-12-2009, 08:43 AM   #2 (permalink)
Favourite Bike: Speed3 -09
Martin_R's Avatar
TuneBoy can read PCIII maps and import them into the fuel trim table. If you already have a PCIII map you like, you should be able to use this without additional dyno time.
Martin_R is offline   Reply With Quote
Old 09-12-2009, 09:56 PM   #3 (permalink)
fat frank's Avatar
Nice to Know
That should definately help and save maybe 18 runs on a dyno., Thanks for the info. Now I need to find someone in Houston who can tune on a dyno.
Thanks for your info.
68 Bonnie Needle Jet Question MNTriGuy Classic, Vintage & Veteran 1 01-18-2009 11:47 PM
Bonnie question! DIRTRIDER01 Classic, Vintage & Veteran 1 09-05-2008 04:12 PM
78 Bonnie Question nuttmeg1 Classic, Vintage & Veteran 13 06-28-2007 11:47 PM
Bonnie question? Kilroy Twins Technical Talk 2 06-06-2007 05:58 PM
Bonnie Question brentde3 Twins Talk 5 11-15-2005 08:29 AM
