good custom Tuneboy tune? - Triumph Forum: Triumph Rat Motorcycle Forums
ECM and FI Tuning - Help, Tips & Tricks We invite members from across TriumphRat.net to post your questions, or share your expertise or experiences on TuneBoy, TuneECU and PowerCommander (etc).
Old 08-22-2009, 07:30 PM   #1 (permalink)
Question good custom Tuneboy tune?
I have read about lots of good "custom tunes" with ignition timing added etc, but cannot find any to download. Something like the 20088tune_Dyno39 or 20102tune_dyno.dat, or anything similar.
06 1050
Zard slip-on
SAI (can plug if necessary)
slight surging around 3800-4000 (hope to cure)
Any suggestions?
Thanks
Bcleatus is offline   Reply With Quote
Old 08-22-2009, 07:41 PM   #2 (permalink)
Favourite Bike: '01 Speed Triple
If you become a Premier Member over at TriumphTorque.net, formerly T595.net, you will get access to the tune library with a lot of choices available.
Speed3 is online now   Reply With Quote
Old 08-23-2009, 11:41 AM   #3 (permalink)
There's not much in the way of 1050 tunes on T595 - I put a couple old ones on there for the 2005-early 2007 models back a couple of years ago. The last time I looked, there was nothing for later 1050 S3s. And because TuneEdit had developed a good bit since then, newer tunes are much more developed.
If you have TuneEdit (TuneBoy), try this tune: Clicky
It is based on the Arrow tune, but better matched to low mount GP style exhausts with SAI. It also smooths out the 2800-4200 surging. It is not perfect (customized to your bike), but should be a decent start.
I hope this helps.
Power-Tripp is offline   Reply With Quote
Old 08-23-2009, 02:12 PM   #4 (permalink)
Thanks!
I'll give that a shot.
Tuneboy Tune bobmcduff Speed Triple Forum 9 04-14-2009 11:56 AM
Specific / Custom Tuneboy tune for MIVV? Sean1970 Speed Triple Forum 0 12-04-2007 08:48 PM
TORS tune from dealer or Tuneboy tune? Max_NYC Speed Triple Forum 25 07-06-2007 11:22 PM
anybody here using the tuneboy and if so what tune do you like king4456 Daytona Deliberations 9 04-10-2007 01:18 PM
Where to buy TUNEBOY?and how to tune? MarkTheBike Triumph SuperSports 1 03-28-2005 04:09 PM
