Racing fuel? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-09-2008, 12:01 PM   #1 (permalink)
Favourite Bike: 2008 Triumph Daytona 675
Orlando's Avatar
Other Motorcycle: Ducati 1098
Racing fuel?
I went to Road Atlanta, and they had a Sunoco fuel station that had HI Octane Racing fuel at the pumps. Is there anything special or different I need to do to my bike to run this fuel. Will it damage the motor by running it? Should I see a big performance change in my bike?
2008 Triumph Daytona 675 Tornado Red
TBR M5 Carbon Fiber slip-on exhaust
BMC air filter
GBRacing frame sliders
PazzoRacing Levers
Orlando is offline   Reply With Quote
Old 09-09-2008, 07:04 PM   #2 (permalink)
Favourite Bike: '06 675 Track Tool
TripleThreat's Avatar
Other Motorcycle: '03 KTM 640 Adventure
I don't think it would be wise to run a motor on high octane fuel unless is has been specifically modified and dyno tuned to run on it. You will run the risk of damaging the motor.
Jeff
NESBA "A" #719
On the Road Less Traveled...
...You Always Meet More Interesting People
TripleThreat is offline   Reply With Quote
Old 09-09-2008, 09:24 PM   #3 (permalink)
Favourite Bike: I love them all equally
Rob377's Avatar
Other Motorcycle: KTM 525 SMR
Extra Motorcycle: Daytona 675
Ideally, you want to run the lowest octane fuel you can without it knocking or retarding the timing. (I don't believe the 675 has a knock sensor that would retard the timing, but it might) Lower octane fuel burns faster and will actually give slightly better power and ecomomy.
Higher Octane will NOT give you anymore power unless your motor is tuned to make use of its increased resistance to detonation.
you might see some gain, 2-4HP by running an oxygenated race fuel, like VP U4 or MR9. (the latter is actually 87 octane) However, without tuning, these would run very lean and eventually melt/destroy your motor. And at the cheapest, you're looking at $75 for 5 gallons for U4. MR9 is well over $100 for 5 gallons.
Long story short, octane has nothing to do with power. Compression does, and compression dictates what octane you can run. High compression motors need high octane fuel because lower octane fuels would detonate 'knock.'
Rob377 is offline   Reply With Quote
Old 09-11-2008, 12:23 AM   #4 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
Exactly. Anything more than midgrade for the street is a waste. I only run premium at the track as a preventative measure due to the high heat involved. Midgrade would probably be fine, and premium is probably a waste.
Will
SponsorHouse profile
Old 09-12-2008, 08:50 PM   #5 (permalink)
I usualy run 93, however I have run sunoco 104 and it seems to make more power. I have the arrow 2 and the arrow factory tune. you guys are 100% right that high octane is for high compression motors. Have you looked at the compresson specs for a daytona? its rather high. im going to have my bike tuned for 104 to get the most out of it but I can feel the difference and the bike seems to run better.
Agkistrodon is offline   Reply With Quote
Old 09-14-2008, 05:04 AM   #6 (permalink)
Other Motorcycle: Ducati Monster
Any additional power is strictly imaginary. The fuel itself actually has less power potential than lower octane fuels. To get more power out of a higher octane fuel, the dynamics of the engine need to be changed. Newer cars can get an increase in power due to variable timing and other changes that are controlled by the ECU.
duk97750 is offline   Reply With Quote
Wolf Racing and Pazzo Racing SPacinelli Triumph SuperSports 13 10-26-2009 07:29 PM
955i Sluggish After Racing Fuel chris1bata Daytona Deliberations 12 08-11-2008 10:24 PM
Anyone Tried Racing Fuel in Speedy? v3rp Speed Triple Forum 13 02-10-2007 11:45 AM
Sprint ST Fuel Line Question (fuel tank to/from fuel rail) Sprint Forum 7 01-26-2005 10:23 AM
