TBR sounds great. I have the exact same thing, M5 Carbon.
The check engine light seemed to have just went away. The only thing I have noticed is that the exahust valve seems to be freaking out at times. When I first got the TBR, doing roll ons in fifth and sixth gear, it would stumble on itself and there was a noticable change in tone, (valve confused).
Also, when you turn on the ignition without actually starting the motor, you can hear the valve searching for a happy spot.
After I got the tune done from the dealership, the above problems on roll ons went away. I am beginning to believe the check engine light is a freak incident when the ECU cannot properly even out due to just the right variables, (temp, altitude, what I had for breakfast, etc.).
I have a buddy with a Tune Boy and he said he'd hook me up if I get the key, we'll see if that helps any.
