Improving lap time - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-15-2008, 03:20 PM   #1 (permalink)
Favourite Bike: D675 SE 2008
kneepad's Avatar
Thumbs up Improving lap time
In thanks to TripleThreat and other (on a thread that went out of hand) I got great track day tips. Consensus on
http://www.triumph675.net/forum/show...t=19258&page=2 Seems like kneedragging is overrated?
TripleThreat wrote:
I think the secret to improving lap times is to not worry about lap times... Use them as a guage, not a goal.
For me, the biggest issue was body position. I had a tendancy to hang my arse way off the bike, but leave my upper body too far over the tank. I always had the feeling that I was hanging from the bars and was having to use them to pull myself back up onto the bike when coming out of a turn.
Much coaching from Control Riders over the last year has led me to the point where I only hang one cheek off the seat and really concentrate on getting my head and upper body low and to the inside when cornering. Ponting the inside elbow down toward the apex of the turn and allowing my outside arm to lay on top of the tank. Remeber to always look as far through the turn as you can, letting your periferal vision take over for the area close to the bike. Look where you want to go, not where you are.
I concentrate on (in a left hand turn for example) getting my left but cheek off the seat, laying the right side of my chest on the left side of the tank and putting my head as low and far forward as possible. Then, pointing my inside (left) elbow down at the apex of the turn. Doing this gets as much weight transferred to the front tire as possible and at the same time, gets your core weight low and inside, which decreases the amount of lean angle necessary to complete a turn. All the while, looking as far through the turn as possible.
Additionally, I found that I was carrying too much weight on my arms as I was in a braking zone (especially in downhill braking zones). This wasn't too much of a problem at lower speeds when all braking is performed in a straight line prior to initiating any lean angle. But, as your lap times decrease and you begin to learn how to trail brake (the application of the front brake as you enter a corner, which keeps the "trail" of the bike shorter, which helps the bike turn in better), the more critical it becomes to remove any unwanted inputs into the bars through your arms caused by braking force.
To remedy this, I had to learn to get back into a tucked position, prior to corner entry, with my crotch right up against the tank and allow my pelvis to absorb the braking forces and completely take the weight off my arms. This allows my arms to remain very relaxed in the turn and allows me the freedom to concentrate on my head and upper body position.
Increasing corner speed is where you will increase your lap times. The best way to learn increased corner speeds for me has been as follows:
Don't change your initial braking marker at first. Just release the brake sooner than you were, allowing the bike to maintain more speed going into the corner (it will stick - trust the tires). As you get more and more comfortable, keep releasing the brake sooner and carry more speed through the corner. Do this until you find that you are starting to miss the apex just a little. Your knee will now probably be dragging in the corner if it wasn't before.
As your mind learns this new corner speed, and you get comfortable, you can then start braking later into the corner and reversing the process a little. Brake later, scrub to the new speed you learned in your mind, gently release the brake and hit your apex.
Use your lap timer to guage your progress, but don't chase a time...
Eventually, you will get to the point where you are trail braking into the turn, using a very, very light touch on the front brake (just enough to close the calipers onto the rotors) until right before you reach the apex - Progressive application of the brakes is critical here. When you initiate pressure at the start of your braking zone, you should just be closing the calipers, then start the weight transfer as your brake harder and harder, as you start to tip the bike in, you should progressively be lightening the pressure on the brakes until just before the apex.
NOTE: This is an advanced riding technique and should only be applied as your comfort level and your skill in progressive brake application increases, as the last thing you want to do is apply too much front brake in a turn - you will loose the front end and lowside with too much front brake.
Then comes throttle application. When you first start riding the track, you will find that you don't really start applying the throttle until you are well beyond the apex of the turn. The same technique applies with throttle application only in the reverse. Start applying gentle throttle or maintenance throttle just as you pass the apex and as you progress you will be able to dial in more throttle, earlier and earlier, until you begin to feel the rear end getting a little squirmy...
The key to going fast is being smooth. Being smooth comes from careful practice and gradual steps. After riding the track for a year and receiving some pretty intense coaching from control riders, I've gone from the beginner class to the advanced class with NESBA. I've gotten to where I feel that I'm fundamentally fairly sound. I can still improve greatly, but the improvements are not as huge at each step now.
Once you are comfortable, you'll come in from chasing a fast control rider after a session and look down at your lap timer and say - holy crap - I didn't feel like I just cut 2 seconds off my best time. That felt so smooth and easy - What a blast... Can we run together next session! Woot!
Sorry for the long post - I didn't realize how carried away I got on this...
If you can't tell... I am a "Track Addict" and NO, I don't want any help...
Wow! What a thread jack...
Yes, as Will stated, the top line or bulge on the dipstick is where the correct oil level is on the 675... And you will be changing the oil far more frequently when riding on the track.
Have fun out there!
Jeff
On the Road Less Traveled...
...You Always Meet More Interesting People
kneepad is offline   Reply With Quote
Old 07-16-2008, 12:15 AM   #2 (permalink)
Favourite Bike: '06 675 Track Tool
TripleThreat's Avatar
Other Motorcycle: '03 KTM 640 Adventure
Just so you all know, I certainly don't claim to be a professional, but the stuff I stated above is all trickle-down stuff from a couple of very fast NESBA Control Riders who got their skills from Freddy Spencer's school.
Their advice helped me move from the NESBA free intro to NESBA's Advanced class in about 10 total track days.
Granted, I've been riding motorcycles since I was 8 years old, so I'm pretty comfortable on two wheels. Plus, I'm a speed junkie and going 150+ MPH doesn't bother me in the least, but it is really their guidance, patience and willingness to drag me around the track and pull me along a little faster lap by lap that has made the difference in my skill progression.
If you attend track days, the absolute best way to improve is to take advantage of the control riders while there and really try hard to apply what they tell you. I guarantee you, you will hear some of the same things stated above...
Jeff
NESBA "A" #719
TripleThreat is offline   Reply With Quote
Old 07-16-2008, 10:48 AM   #3 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
I absolutely, positively second what Jeff says about getting instruction. I did trackdays on a very casual basis for three or four years- two or three a year, and didn't get any instruction. As a result, I ended up with some pretty bad habits and when I finally got some instruction, they proved hard to break.
Will
SponsorHouse profile
Old 07-16-2008, 11:24 AM   #4 (permalink)
Favourite Bike: 02 Sprint ST
sprintboy's Avatar
Other Motorcycle: Daytona 675
That is all great information! I'm a newby to track days and am finding it a fascinating learning experience. at this point I'm going through the "getting the body position correct" phase. It feels like I'm doing it right when I'm on the track and I'm leaning the bike like never before in the corners and thinking to myself "the knee has to touch soon!" but it never did. When I got the photos from the track photograpner (a great learning tool) I could see that my head was still centered on the tank and way to high. next time I'll concentrate on the body position and the lap times and knee down will come automatically.
It's a tricky thing, not unlike a good golf swing, or learning to roll a kayak, it's all about muscle memory and getting everything right and feeling natural. I imagine once you get it right you won't have to think about it again. I just have to get it right. It sure is fun trying!
Thanks for the great information!!!
Sprintboy
slow track addict.
sprintboy is online now   Reply With Quote
Improving the indicator light ChrisV Twins Technical Talk 22 04-23-2009 05:56 PM
Improving Cornering Clearance Jamie Street Triple Forum 14 06-25-2008 12:42 PM
improving 07 luggage security argh Sprint Forum 12 09-24-2007 10:06 PM
Improving the lighting.... Drunktank Speed Triple Forum 25 02-21-2007 12:28 PM
S4 Improving comfort? ManxKat Triumph SuperSports 18 10-23-2006 03:22 PM
