| Daytona675 Forum D675 Riders and Enthusiasts |
06-20-2008, 01:25 PM
Official Leathers Tester
Site Supporter Team Owner Favourite Bike: Very fast 675
Posts: 5,419 Other Motorcycle: Very stationary Commando Extra Motorcycle: Mad Max the Husqvarna
Oil Leak
This is an odd one. I have an oil leak from somewhere, but I haven't been able to find it. I have had the stator cover off and on twice now, and checked the drain plug washer with no luck. It makes a mess inside the left lower fairing, but I haven't found it yet. I have some theories, but haven't tried them out. I may replace the chain and sprockts soon, and when I do, I will check the countershaft seal, but I don't think that's where the oil is coming from. I have checked the transmission shift linkage seal, and it is OK. The strangest part of the leak is how intermittent it seams. I am a bit stumped for the time being. Once I figure it out, I will post up about what I found so it may help somebody in the future.
Will
SponsorHouse profile
06-20-2008, 01:29 PM
Site Supporter SuperBike Favourite Bike: '06 675 Track Tool
Posts: 1,704 Other Motorcycle: '03 KTM 640 Adventure
Just curious Will, what type of chain lube are you running. Is it possible that the chain lube is getting hot and flinging off onto the inner fairing or are you pretty sure it's motor oil?
Are you showing any oil consumption over time that might be a result of the leak?
Let us know what you find.
Jeff
NESBA "A" #719
On the Road Less Traveled...
...You Always Meet More Interesting People
06-20-2008, 11:38 PM
It is engine oil for sure. I can watch the level drop over time. Beats me where the leak is from, but it is pretty frustrating, since the bike hasn't used a drop of oil until it started to leak.
Will
06-20-2008, 11:54 PM
When you put the stator cover back on, do you put the copper washer back to the original position? Because the bolt that has the copper washer on it runs through some oil channels. I had the same problem with my clutch side.
06-21-2008, 11:09 AM
Yep, I did. I thought the copper washer had something to do with electrical connectivity, but I guess not. I will check it again. Thanks for the suggestion.
Will
07-23-2008, 07:44 PM
Resurrected thread. After chasing the leak around for what seems like ever, it was apparently a backed out bolt on the sump. It was just enough to let the oil seep out between the bottom of the engine case and the top of the oil pan, but not enough to let it leak if the motor wasn't running and pressurizing the oil. It makes no sense that the sump would be the problem when the oil has to be under pressure to leak, but tigheting it back up seems to have solved the problem for now.
Will
07-24-2008, 12:28 AM
Will,
Glad you got it sorted...
Jeff
NESBA "A" #719
07-24-2008, 01:07 AM
Actually, I didn't. It dumped a lot of oil again. It is extremely random. I guess I am going to have to take off the plastic, dust it down with Desnex (the secret weapon in leak hunts) and ride around until the leak turns up. Crashing sucks. I have been chasing this leak almost a year.
Will
07-28-2008, 04:16 PM
That sucks Will,
Let us know what turns up.
Jeff
NESBA "A" #719
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Oil Leak
bonza |
Twins Technical Talk |
23 |
09-19-2009 09:41 AM |
oil leak or no?
GCA |
13 |
07-06-2007 09:00 AM |
oil leak
ricster |
Sprint Forum |
1 |
06-07-2007 12:04 AM |
oil leak
BTMOTO |
Triumph SuperSports |
6 |
07-23-2006 08:04 PM |
Oil Leak
Sprint Forum |
16 |
09-29-2004 01:44 PM |
