The OEM Pirellis are a funny hybrid tire. They are street compound tires with a racing pattern on a street carcass. You can only get the OEM tires by ordering them from a Triumph dealer. If you get Dragon SuperCorsa Pros from somebody else, chances are they will be DOT race tires, and not the best idea for use on the street. I don't know much about Pirelli race tires, but typically you start out with some funky low pressures in DOTs. Their carcasses are usually much stiffer than street tires. I would recommend the Diablo Corsa IIIs over SuperCorsa Pros if the SuperCorsas are racing DOTs.
Will
SponsorHouse profile
