Brooksie,
Turn the cable adjustor screw all the way into the lever perch to maximize free play. Then, sort of bend the lever backwards from the normal direction of travel with the pivot bolt already removed. That should allow the cable to slide out. Reverse this procedure on the installation. Make sure you put the brass bushing in the one side (can't remember which now, but it should be obvious).
Make sure you adjust the free play in the cable after you complete the installation.
TripleThreat
On the Road Less Traveled...
...You Always Meet More Interesting People
