Originally Posted by TripleThreat
Quite possibly also the intake flapper valve. Many people have had squeeks coming from this valve also...
Of course, +1 to that. I forgot about the intake flapper as it is always open if You are using a map for a slip-on. With a OEM-bike the intake flapper open/close exactly at 4 500 RPM, so it could very well be this valve.
However - it is quite easy to check: If the squeek comes from the front of the bike, it is probably the intake flapper and it can be lubricated. If it is coming from the right lower parts of the bike, it might be the exhaust valve.
Good luck Rich!
