Originally Posted by Panthers_Den
So I was wondering if it was possible to set up the 675's with dual low/high beams like the US Sprint ST's are. So when the low beams are on, both left and right lights are on and when you turn the high beams on, both go from low to high...
There is a modification available to set up the 675 so the when the low beams are on, both the left and right lights are on. The kit allows the highbeam to turn on with the low beam and makes the high beam light adjustable.
http://www.eclipze.com.au/twinlight/main.html (Eclipze is awesome to work with and has sold a lot of these to 675 owners).
It will not allow both lights to go to high beam though. As far as I know, no such mod for the 675 has been made to allow this feature.
Question 2, Is this setup possible on the 675 with an HID conversion kit?
Yes. There is an Apexcone HID kit(s) available for the 675. -->>
http://triumph675.net/forum/showthread.php?t=10486
