The rear spring is pretty stiff for some reason. The front forks don't seem as stiffly sprung to me, but I am not exactly the most sensitive test rider. When I got my bike set up with the stock shock, the sag was set way too soft, even with a hard spring. Likewise, the front forks needed some preload as well. I didn't have too many problems with the bike's geometry once it was set up, until I lowsided on a cooked set of tires. Now, my bike is set up with an aftermarket shock and with the fork tubes pulled down to flush with the top clamp. I also cranked the shock's adjustment to full height, and it is really twitchy. I need to lower the rear back down to some reasonable height in order to get things back under control.
This probably isn't the most helpful information, but it gives you an idea of what happens when you do this or that to the bike. Anything you do to raise the front or lower the rear will be OK, but raising the rear is a bad idea, as is dropping the front. Aside from replacing the shock and rebuilding the forks, getting the sag sorted and the front ride height sorted are the most important things you can do.
Will
