Motorcycle.com
Daytona675 Forum D675 Riders and Enthusiats
Old 11-25-2007   #1 (permalink)
adepackett's Avatar
675 cutting out intermittantly
hello there fellas
i was wondering if anyone out there has run into the same problem as i have at the moment?
i have a 2006 675 at my shop for a 12000 mile service inc valve adjustment,it is stock except for a jardine slip on pipe and my customer had a tuneboy tune downloaded to run no o2 sensor and it has the fuel pump relay update done by another dealer
after doing the service with no problems the bike now runs fine but puts a unknown fault code p1105 in the ecm,when i clear the code it has a poor idle and cuts out intermitantly.after a minute or so the code returns and the bike runs great again!! in other words it runs good with a fault code in the box]
i have the triumph fuel pressure tester hooked up and its the first time on a 675, the needle seems to flutter at idle more so than when hooked up to earlier speed triples inc 1050's,rockets,sprints,
i see there is a new fuel pump on this model and wondering if any of you guys have run into a similar problem or any issues with the relay update?
thanks a lot
adrian
www.adepackett.com
SPEED?.....its all a question of money............................................. .,HOW FAST DO YA WANNA GO?
adepackett is offline   Reply With Quote
Old 11-25-2007   #2 (permalink)
Moderator
Favorite Bike: '06 Graphite 675
TripleThreat's Avatar
Extra Motorcycle: '06 675 Track Tool
Does it sound like it's chuffing at idle? If so, double check all of your vacuum lines. Having had the tank and airbox off for track day mods, I've found that it is easy to dislodge a small vacuum line that will cause a chuffing at idle and a check engine fault light to come on. Once the vacuum line is reinstalled and the fault light is cleared, everything goes back to normal.
Not sure if it will help, but it seems to have been a fairly common occurance among those of us who have our tank off frequently.
Jeff
On the Road Less Traveled...
...You Always Meet More Interesting People
TripleThreat is offline   Reply With Quote
Old 11-25-2007   #3 (permalink)
Favorite Bike: Very fast 675
Will's Avatar
Did the Tuneboy map turn off the o2 sensor or do something funny with it? My guess something to do with the map and the sensor. If you can find out what the map is and who made it, it might help, too.
Will
Will is online now   Reply With Quote
Old 11-26-2007   #4 (permalink)
adepackett's Avatar
fixed!
hey up fellas
thanks for your help and input,the problem turned out to be a software problem from the tuneboy map,i reinstalled the genuine triumph fuel map with the actia tool.
if anybody needs remaps i can do tuneboy maps[which i always seem to have no end of problems with!!] or i have the actia tool for genuine remaps whic i find a lot more reliable myself...................
thanks
adrian
www.adepackett.com
cutting out greasygraeme Speed Triple Forum 6 2 Weeks Ago 08:48 AM
Cutting Out brianre Tiger Workshop 7 08-25-2007 09:37 AM
Engine cutting out bazzerf Modifications & Workshop Talk 4 05-12-2007 06:25 PM
engine cutting out funderbird Hinckley Classic Triples 14 10-26-2006 11:11 AM
Headlight cutting out Xan Daytona Deliberations 1 08-25-2005 04:40 PM
