Daytona675 Forum D675 Riders and Enthusiats
Old 05-07-2007   #1 (permalink)
yamaha17
well i layed my bike down a few weeks ago and the right frame slider ended up bending in a cracking my cylinder head and cam cover....so i pulled the motor and replaced the head and cam cover, and the whole works....i put it back in the bike, and it cranked and runs fine,no leaks, but not perfect it sputters a little bit and sometimes shuts off after you rev it up..... but the CHECK ENGINE light is on, so i was thinking that maybe it is in some fail safe mode with that light on....how can i turn it off and reset it with out the triumph diagnostic tool?... :???:
Old 05-07-2007   #2 (permalink)
iceman017
hey man. you need the tool. bite the bullet and go to a reputable triumph dealer and pay them to check out your bike. I'm a mechanic at a duc/tri/apr/ktm/polaris/vespa shop and specialize on Ducati, Triumph, and KTM. I just bought a 675 yesterday as my new racebike ... you should get it checked out at the risk of messing up the new parts. if it's just an error, it shouldn't take them more than 15 minutes - but you should make sure.
Old 05-08-2007   #3 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
If everything is fine, it will turn itself off after three heat cycles. Considering what your bike has been through, I would probably get it checked out.
Will
SponsorHouse profile
Check engine light...on again off again monroe731 Sprint Forum 7 04-11-2008 03:53 PM
What the Heck Daytona 675 Check Engine Light smokinchaplain Daytona675 Forum 5 07-29-2007 05:34 PM
check engine light Quietsouls Speed Triple Forum 7 12-13-2006 10:52 PM
675 check engine light duckman999 Daytona675 Forum 1 12-10-2006 02:52 PM
Check engine light Speed Triple Forum 1 07-02-2004 01:19 PM
