Sport touring my 675R - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com
Old 11-22-2012, 06:40 AM   #1 (permalink)
Main Motorcycle: '05 Bonneville Black
Bhodi513's Avatar
Other Motorcycle: '12 Daytona 675R
Extra Motorcycle: '78 Yamaha SR500
So I have decided to see the country on my 675R (well the states around Ohio at least). I have bought some heli-bars, some Pilot 2's, a bigger windscreen, gel seat.... I think that is it. My question refers to the suspension. I have my bike set up now for me with my track gear on. Is it feasible to ride down to my local dealer with my touring luggage loaded up and have them set me up for touring in such a manner that I know how to get back to my original settings? I ultimately want to know the difference between the two so I can switch back and forth. Would the suspension stay consistent enough to be able to do this? Or will I have to go through the entire process of measuring, adjusting etc?
Thanks
AB
Bhodi513 is online now   Reply With Quote
Old 11-22-2012, 08:32 AM   #2 (permalink)
Main Motorcycle: '06 675 Track Tool
TripleThreat's Avatar
Other Motorcycle: '03 KTM 640 Adventure
Very possible...
Before you take it to have it set up:
Take a screwdriver and turn each clicker in to full stop, counting the clicks as you adjust. Return them to that setting and move to the next adjuster.
Be careful to record each one in a manner that you will be able to remember which one was which...
Take the bike to the dealership and have them set the suspension up for you with your touring setup.
Return home and repeat the process above.
You should then be able to recreate each setup by simply screwing each adjuster in to full stop and then back off and count the clicks to get to the desired setup.
Once you do this, it also frees you up to begin making minor adjustments as you ride to see if you can fine tune your setup. I found that measuring and setting sag only accomplished part of my setup needs, especially at the track. With these setting recorded, you can always go back to a baseline setup.
It will be a little more complex if you adjust preload, especially on the rear shock since that is accomplished by adjusting the locking collars on the bottom of the spring housing, but you can count the number of threads exposed just like you can count the rings exposed on the front fork preload settings.
Writing everything down in an organized manner will allow you to return to a known setup as you fiddle with it...
NESBA "A" #719
On the Road Less Traveled...
...You Always Meet More Interesting People
TripleThreat is offline   Reply With Quote
Old 11-22-2012, 09:48 AM   #3 (permalink)
Bhodi513's Avatar
Thank you very much. That all makes total sense. That brings up another question I have now. Will my suspension "break in" over time?
AB
Old 11-23-2012, 09:08 PM   #4 (permalink)
Official Leathers Tester
Main Motorcycle: Very fast 675
Will's Avatar
Other Motorcycle: SV650 Track Weapon
Suspension deteriorates over time as the oil ages and turns to sludge. If your bike is brand new, then rebuilding anything won't make much difference, but once the bike is a few years old, refreshing the fork oil and shock will make a world of difference.
Will
SponsorHouse profile
Will is online now   Reply With Quote
touring or sport/fun ? mr1bienvenu Twins Talk 13 10-19-2011 11:43 AM
Sport & Touring for the '07s? Mudhen Tiger Chat 26 01-02-2007 10:32 AM
Sport Touring Daytona???? Isa Daytona Deliberations 8 10-18-2005 04:46 AM
1200 For 2 up Sport Touring 99d12 Daytona Deliberations 3 07-14-2004 01:29 PM
