squeaking noise while shifting - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!
Old 07-30-2012, 11:28 PM   #1 (permalink)
Newbie
Main Motorcycle: 675
I am getting a squeaking noise when I pull the clutch in while I shift.
I believe it is coming from the front fork. pretty sure it is. what does this sound like? Thanks
2009 675
Krause95 is offline   Reply With Quote
Old 11-04-2012, 07:39 PM   #2 (permalink)
Main Motorcycle: 2009 Speed Triple
weekdaywarrior's Avatar
2009 675
Does the squeaking also occur whenever you rev past 6500 rpm or so? I'd check that. If so it just a slightly rusty/dirty intake flap. Mine squeaks when I rev up past 6,500 and everytime I clutch in and shift the rpms dip below 6,500 and it squeaks again.
weekdaywarrior is offline   Reply With Quote
Old 11-07-2012, 05:07 AM   #3 (permalink)
Main Motorcycle: sprint 1050
Could it be the power valve?
StevyR is offline   Reply With Quote
Old 11-07-2012, 05:43 AM   #4 (permalink)
Main Motorcycle: Daytona 675
It's the air intake flapper, opens up around 6000rpm.
Keeps intake noise level down at lower RPM's
Manufacturer will say it improves power etc etc, unlikely
PikeyJ is offline   Reply With Quote
Old 11-07-2012, 05:17 PM   #5 (permalink)
Official Leathers Tester
Main Motorcycle: Very fast 675
Will's Avatar
Other Motorcycle: SV650 Track Weapon
It doesn't. Otherwise, it would still be in operation when the off-road maps are loaded up. The TOR map has it open at 900 rpm (essentially at idle), and I'm not sure what the Arrow map does. Most people I know who are trying to get an extra horsepower or two out of a 675 motor just remove the whole vacuum system and call it a day.
Will
SponsorHouse profile
Should my brakes be squeaking like this? Malcolm21 Twins Technical Talk 6 09-05-2011 08:19 AM
Squeaking Brakes samats Twins Technical Talk 1 07-26-2006 01:39 PM
squeaking then resonating noise in TT600 rear cparris Triumph SuperSports 7 05-03-2006 05:15 PM
squeaking then resonating noise from TT600 cparris Maintenance & Workshop Talk 0 04-29-2006 02:19 PM
chirping & squeaking skidded Hinckley Classic Triples 3 05-05-2005 10:51 AM
