Bar Riser Options for Daytona 675 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-13-2010, 11:45 PM   #1 (permalink)
Thumbs up Bar Riser Options for Daytona 675
This is something I'm interested in myself, and I thought other may be interested as well.
Option 1.) Switch and flip the stock clip-ons.
http://www.triumph675.net/forum/show...apping+clipons
Pros: Cost - anywhere from free to a few dollars if you do it yourself.
Cons: Some people feel that because the bars this way are too flat in profile they feel awkward, and hurt performance during aggressive riding.
Option 2.) SpeedyMoto - Adjustable Superbike Clip-Ons
http://www.speedymoto.com/
Option 3.) Woodcraft
Pros: Less expensive than others. The standard "Low" 1" risers should work with no fairing modification required.
Cons: Taller versions are available, but will require either faring spacers or the fairing to be trimmed accordingly.
http://www.woodcraft-cfm.com/Scripts...dproduct=18060
Option 4.) HeliBars
Pros: A well made product that works as advertised. People that have them have given very positive reviews of them.
Cons: Some may not be able or willing to pay the asking price for these new, which as of 12/14/09 is $284.00.
http://www.helibars.com/product/trac...tona%C2%AE-675
Option 5.) Apex - Riser Clip-ons
Pros: Good range of adjustment available, reasonably priced at $189.00.
Cons: Depending on the setting chosen, additional cable lengths and fairing trimming may be required. Beware that Daytona 675 owners are reporting fitment and other problems, do some research on this.
http://www.apexmfg.com/riser.htm
Last edited by Tbirdnz; 06-13-2011 at 09:17 PM. Reason: additional links added per authors request
Sentinel is offline   Reply With Quote
Old 09-13-2010, 11:46 PM   #2 (permalink)
Option 6.) LSL
2006 - 2008: LSL - Daytona 675 06-08 Z150T037
Pros: 1 1/2" Rise
Cons: Fairing spacers are provided and must be installed to prevent the bars from contacting the fairing. Also longer stainless steel break-lines and a break fluid reservoir mount are required and are provided with the kit.
2009 - 2010: Daytona 675 09- Speed Match Z153T045R
Pros: 1" Rise, no modifications necessary.
Cons: Only a 1" rise.
http://www.spieglerusa.com/
Option 7.) Gilles Variobars
Pros: A very high quality product with various riser options available..
Cons: As with some of the other solutions mentioned here, some changes such as longer control lines and possibly some fairing modification may be required.
Gilles bars almost installed - Triumph675.Net Forums
http://www.gillestooling.com/
Option 8.) ConvertiBars
Pros: Virtually infinitely adjustable; more so than any other option here. They can even be adjusted while out riding. For example, you could have them higher for commuting, and at the foot of the canyons you can pull over and drop them down for carving.
Cons: Some may not be able or willing to pay the asking price for these new, which as of today is $339.95, and is the most expensive option here.
http://www.convertibars.com/HowitWorks.cfm
http://www.convertibars.com/ProductsBike.cfm?Action=Add&ProductID=&rebuildStru ct=1&CategoryID=-1&BikeYear=2009&MakeID=77&ModelID=215&btnSubmit=+N ext+Step!+
Option 9.) Tarozzi Clip-ons
Pros: Choice between Low-rise 40mm (1.6") higher, or High-rise 70mm (2.8") higher. Four different positions available, also angle adjustment. Reasonably priced.
Cons: Depending on the year or your bike you may need to do some fairing trimming, and for the High-rise version longer control cables may be necessary.
http://www.fastfromthepast.com/servl...ons/Categories
Last edited by Tbirdnz; 06-13-2011 at 09:17 PM. Reason: additional links added per authors request.
Old 09-13-2010, 11:47 PM   #3 (permalink)
More options to come!
Last edited by Sentinel; 09-13-2010 at 11:58 PM. Reason: This post is a place holder... not enough pics allowed per post...
Old 09-13-2010, 11:47 PM   #4 (permalink)
Even more options to come!
Last edited by Sentinel; 09-13-2010 at 11:59 PM. Reason: This post is a place holder... not enough pics allowed per post...
Old 11-15-2010, 01:57 AM   #5 (permalink)
Main Motorcycle: '11(2010) Speed Triple SE
BradManUWF's Avatar
Other Motorcycle: '08 Daytona 675
I've got the Heli Bars and they definitely make the angle of my wrists more comfortable. Like mentioned above, the $284 is pretty high(got mine new on ebay for half that), so the price being worth it or not will depend on how much time you spend on your 675.
BradManUWF is offline   Reply With Quote
Old 06-13-2011, 10:43 PM   #6 (permalink)
Official Leathers Tester
Main Motorcycle: Very fast 675
Will's Avatar
Other Motorcycle: SV650 Track Weapon
For future reference.
Will
SponsorHouse profile
Daytona 955i Handlebar Riser Job phpbiker Daytona Deliberations 4 09-04-2009 08:48 PM
Frontend options on the Daytona The Wild Wong Daytona675 Forum 2 08-03-2008 02:12 PM
Riser bars on a Daytona? danfost Daytona675 Forum 8 05-17-2008 01:48 PM
gearing options on 04 daytona 955i MQracing Daytona Deliberations 7 10-03-2007 05:33 AM
Daytona 1200 luggage options Bowenman Daytona Deliberations 13 10-11-2005 07:24 PM
