The little metal rod that the spring goes through does not move. There is a threaded ring that goes around the outer plastic portion of the switch body. Twisting that threaded ring moves the entire switch body up and down in the rearset. There is no need to remove the spring to adjust the switch sensitivity.
If you need pics, let me know...
NESBA "A" #719
On the Road Less Traveled...
...You Always Meet More Interesting People
