The real problem with cutting carbon fibre.... Although most have hit the nail partly on the head, with the difficulty in not cracking the resin, is the fact that the fibres are pretty tough to cut in them selves.
The carbon fibre woven fabric is relatively easy to cut at 90 degrees with a pait of scisors (before it's soaked in resin) but you're effectively holding it still with the existing resin and tryind to cut against the resin surface with a single blade.
Using a dremmel can work but don't try it wih an abrasive end ... you must use a cutting bit, using an abrasive the ege off the hole will just go furry.... (unless your'e very lucky) the resin breaks away and leaves the fibres
Used the sharpest hardest drill you can ...... cobalt for prefference... but a brand new HSS drill is a good idea.... BTW running the drill backwards the eghe of the carbon fibre will just fo furry and clog things up.
How do I know ...... I build high speed boats in carbon fibre for a living ! ....... Check out
www.xsmgworld.com for a serious toy .....
(prices start at £1.2 million UK Pounds)
Have Fun.....
