Bike won't crank!! - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 12-03-2009, 05:43 PM   #1 (permalink)
Newbie
Question Bike won't crank!!
I have been riding the bike as a daily driver for the last 5 months. I just rode the bike, without issue, 8 hours ago. Now i go to start the bike but it will not start. I turn the key on, the gear is neutral, the clutch is held in. I press the ignition the bike clicks once then the gauges and fuel pump restart as if i had just turned the key to the on position. I hear a click from under the seat area but that's it.
I replaced the batter but that did not change the issue at all. I tested both batteries and they are both good.
Has anyone had or heard of this?
skyhigh21 is offline   Reply With Quote
Old 12-04-2009, 01:14 PM   #2 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
This is going to sound stupid, but make sure the battery terminals are screwed down good and tight. If this doesn't work, then you have a faulty connection somewhere else, most likely.
Will
SponsorHouse profile
bike wont crank! LuckyDogSE Daytona675 Forum 4 11-09-2009 05:10 PM
Bike for sale with 76 Offset Crank? Normsthename Classic, Vintage & Veteran 1 09-14-2008 03:34 PM
Another 360 degree crank bike arriving soon ohiorider Twins Talk 1 08-27-2008 10:07 PM
Help! Bike Died this morning. Crank no start. RivMan Triumph SuperSports 6 10-10-2007 03:23 AM
2000 rs crank wounlt crank KidThunder650 Sprint Forum 3 04-15-2006 06:16 PM
