Service Manual doesn't list a resistance value...
Here are the diagnostic tests according to the service manual...
Fault Code P0107
MAP Sensor Short Circuit to Ground
Fault Code P0108
MAP Sensor circuit, short circuit to supply or open circuit
Fault Code P1105
MAP Sensor Pipe Fault
Pinpoint tests
Test 1
Check cable and terminal integrity
If OK - Proceed to test 5
ECM pin A28
ECM pin B20
ECM pin B01
If Faulty, rectify Fault, Proceed to test 3
Test 2
Check cable for short circuit
If OK - Proceed to test 3
ECM pin A28 to ECM B20
Short Circuit, Locate and rectify wiring fault and proceed to test 5
Test 3
Check cable for continuity
OK - Renew MAP sensor and proceed to test 5
ECM pin A28 to sensor pin 1
ECM pin B20 to sensor pin 2
ECM pin B01 to sensor pin 3
Test 4
ECM pin A28 to ECM pin A01
Short Circuit - Locate and rectify wiring fault and proceed to test 5
Test 5
Reconnect harness, clear fault code and run engine
OK - Action complete, quit test
Fault still present - Contact Triumph Service
Not sure if this is any help, but it's all I've got...
NESBA "A" #719
On the Road Less Traveled...
...You Always Meet More Interesting People
