Help me with my bar ends!!!! - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-28-2009, 09:17 AM   #1 (permalink)
Newbie
Can anyone tell me how to remove the factory bar ends from a '08 daytona 675?
sully675 is offline   Reply With Quote
Old 10-28-2009, 09:33 AM   #2 (permalink)
Favourite Bike: '06 675 Track Tool
TripleThreat's Avatar
Other Motorcycle: '03 KTM 640 Adventure
Roll the outer end of the grip back just a little. You will see two holes, top and bottom in the bar. Inside these two holes, there is a little clip that holds the bar end in place. Press those clips to release them from the hole and pull the entire bar end out of the bar.
The bar end and a long steel rod with rubber bushings will all pull out. The whole assembly is about 8" long I would guess...
NESBA "A" #719
On the Road Less Traveled...
...You Always Meet More Interesting People
TripleThreat is offline   Reply With Quote
Old 10-28-2009, 09:46 AM   #3 (permalink)
Newbie
Awesome.
What a mission!!
Thanks. Worked on the clutch side. Any ideas on how to do it on the throttle side? the two holes are under the throttle.
Old 10-28-2009, 04:27 PM   #4 (permalink)
Loosen the screws (make sure you have a really good screw driver) on the throttle assembly. This will allow the entire throttle assembly to slide in toward the brake perch, thus exposing the end of the bar and the holes will be accessible.
NESBA "A" #719
Old 10-29-2009, 05:06 AM   #5 (permalink)
Newbie
Thumbs up
that wasnt so hard once i knew what i was doing.
Thanks for the help mate
Old 10-29-2009, 02:37 PM   #6 (permalink)
Happy to be of some help...
NESBA "A" #719
Bar ends patrol21 Hinckley Classic Triples 11 04-02-2008 04:18 PM
It never ends huh? keysersoze Speed Triple Forum 21 06-01-2007 03:29 AM
Bar ends mepeck Club Cafe' 6 03-14-2007 08:32 PM
Bar Ends VelvetHog Speed Triple Forum 16 08-28-2005 01:42 PM
