2007 No Start...faulty ecm? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-04-2009, 08:28 PM   #1 (permalink)
Newbie
I recently traded a running 600 for a non running 675. After replacing fouled plugs I got it started but it won't run at idle. It has multiple codes including map, baro, iat, exhaust valve. Sometimes if I reset the ecm it will idle but not rev(complete opposite) and will have a total different set of codes! My theory is the former owner who washed the bike and got water in the spark plug tubes fried the ecm while testing. I don't want to waste my money on an ecm if it won't fix it. I found someone with a 2008 ecm and plugged it in but it wouldn't crank then. Is there an initializing process or will this ecm simply not work on my 2007? Anyone? I really want to get this bike going!
cam3281 is offline   Reply With Quote
Old 10-04-2009, 10:09 PM   #2 (permalink)
Favourite Bike: 2012 Daytona 900
Brooksie's Avatar
Other Motorcycle: 2008 Kawasaki ZX14
I'm not an expert, but if the battery was dead for any length of time, the bike may need to be reprogrammed. I don't see water being the issue unless it was high pressure.Hang in there, there are some experts at this site that can help.
Brooksie is offline   Reply With Quote
Old 10-05-2009, 10:08 PM   #3 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
Next time you try it, write down the codes. Maybe they will help figure it out.
Will
SponsorHouse profile
2007 Speed Triple Will Not Start raydeje Speed Triple Forum 19 09-14-2009 09:36 PM
Rev counter faulty tt600ryder Triumph SuperSports 3 06-04-2009 05:05 PM
Faulty Rad Pressure cap? 944lut Hinckley Classic Triples 11 11-03-2007 11:27 AM
1-3 and now 1-4 - what a start to 2007! TonyD Biker Hang-Out 3 01-10-2007 04:41 AM
My 2007 sprint wouldn't start chefjohn Sprint Forum 1 01-08-2007 02:56 AM
