check ebgine light - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-16-2009, 05:29 PM   #1 (permalink)
sarky's Avatar
check ebgine light
i have a 2010 675 and the check engine light came on today, when i started it up first thing this morning. It stayed on for 150km, then just went out. The bike runs fine, any idea, im going to the dealer for my 1000km service thrusday and i will habe them check it then just curious.
sarky is offline   Reply With Quote
Old 08-16-2009, 07:16 PM   #2 (permalink)
Favourite Bike: '06 675 Track Tool
TripleThreat's Avatar
Other Motorcycle: '03 KTM 640 Adventure
Most likely an ExBv Exhaust Valve adjustment issue (Pretty Common). It's in the exhaust pipe just past the Catalytic Converter. Dealer should be able to tell when they service the bike.
NESBA "A" #719
On the Road Less Traveled...
...You Always Meet More Interesting People
TripleThreat is offline   Reply With Quote
Old 08-18-2009, 05:26 AM   #3 (permalink)
Favourite Bike: 2008 Triumph Daytona 675
Orlando's Avatar
Other Motorcycle: Ducati 1098
yea, my 2008 D675 did the same thing and it was brand new, I thought I had purchased a lemon or something. I took to dealership 3 times after that for the same issue, finally had the exhaust valve changed out, warranty work!!! Keeping fingers crossed no issues in about 2500 miles. Enjoy your bike!!!
2008 Triumph Daytona 675 Tornado Red
TBR M5 Carbon Fiber slip-on exhaust
BMC air filter
GBRacing frame sliders
PazzoRacing Levers
Orlando is offline   Reply With Quote
Old 08-19-2009, 08:23 PM   #4 (permalink)
sarky's Avatar
well u guys were right it was the exhaust valve, they just reset it so im waiting for it to pop back on
2010 675 special edition
Old 08-25-2009, 02:49 PM   #5 (permalink)
Favourite Bike: D675 SE 2008
kneepad's Avatar
Smile Mellow yellow light
I had the same thing going on a 2008 under warranty. The lamp is actually called MIL (Malfunction Indicator Lamp) and when the sensor in the exhaust butterfly valve register something and turns the light on, it normally turns off the MIL after 3 no-fault warm-up cycles. The error code (in this case P1080) is stored in the ECM memory and after 40 no-fault warm-up cycles it's erased from the ECM.
With a TuneBoy you can diagnose and erase error codes.
kneepad is offline   Reply With Quote
Old 08-27-2009, 05:02 PM   #6 (permalink)
Also have a new 675se. My engine management light came on the other day, took it to the dealers and they stated that the noise emission valve in the exhaust is playing up. They reset it and asked that I gave them feedback as to what happened from thereon in. The bike was fine while out all day. Once it was cool at the end of the day I turned it on, fine, started it, fine, blipped the throttle and the light came on! New bits ordered and booked in for them to be fitted. The latest models are supposed to have the modified bits that don't do this, can't say I'm that impressed. They might be doing it for free but it's the hassle involved. Oh, had a dreadful job starting it the other day when the ECU sounded like it had tied itself in knots which I believe is related to the exhaust valve. Tried it today and it started first time without complaint.
Dave675se is offline   Reply With Quote
Old 08-31-2009, 03:49 PM   #7 (permalink)
kneepad's Avatar
Lightbulb DIY Ex butterfly valve
Check this out:
http://www.triumph675.net/forum/showthread.php?t=21392
Old 09-01-2009, 11:42 PM   #8 (permalink)
Interesting discussion. Mine's only around 5-6 weeks old so it's currently in the dealers having new exhaust parts fitted. I was told by the dealer when they diagnosed the valve as playing up that it's only a noise emission part in any case, doesn't affect power at all. It certainly hasn't made any difference to the power of mine but it sounds marvellous when the valve sticks open at the low revs end. I did ask whether they could just set it full open all the time, I'll find out whether they could when I collect it.
Check engine light...on again off again monroe731 Sprint Forum 23 03-20-2010 11:14 AM
Check engine light is on Lucky77 Twins Talk 6 06-28-2009 05:29 PM
675 check engine light.....help!!!! yamaha17 Daytona675 Forum 2 05-08-2007 12:01 PM
Why is my check engine light on? fivehundo Daytona Deliberations 4 07-30-2006 02:55 PM
12K check done...eng. light on??? Milo Maintenance & Workshop Talk 2 05-22-2004 08:18 PM
