Rear preload - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-27-2009, 09:34 PM   #1 (permalink)
Favourite Bike: '07 Daytona 675
jklnhd's Avatar
Other Motorcycle: Huffy Nevada, 10 spd
Rear preload
Okay, the coilover setup in the rear is slammed on my bike (last owner = chic, probably not quite as tall, makes sense I guess).
I get how to adjust it, but where should it be (stock)?
I'm trying to get everything back to factory looks/settings, so I can start playing with adjustments from where they came from.
Also, any idea on what a 2-year/12k mile service usually runs? Haven't been able to talk to dealer yet.
I used to be apathetic, now I just don't care.
jklnhd is offline   Reply With Quote
Old 07-28-2009, 05:02 PM   #2 (permalink)
Favourite Bike: 2006 Daytona 675
Other Motorcycle: 1999 Daytona 955i
Extra Motorcycle: 1997 Daytona T595
You should have a couple friends help you set your rider sag if you're going to be down there anyways. You can look up directions on how to do it on sportrider.com (they have very specific directions), but it's not rocket science. You will need a couple friends to help, but give them beer and they'll do it happily.
If you get giddy... pick yourself up a straight-rate spring that's rated to your weight and toss the stock rising-rate 'one size fits all' spring.
Grashopr is offline   Reply With Quote
Old 07-29-2009, 06:48 PM   #3 (permalink)
jklnhd's Avatar
Thanks for the info, I'll check it out. I didn't think it'd be too bad, kinda looks like a normal coilover deal anyway.
I'll look into the spring too, but will that cause any issues with a passenger? Not that I do a lot of hardcore Rossi-wannabe riding with a passenger, but she'll be on the back until I scrounge the cash for an EX250 or something.
Old 07-30-2009, 03:32 AM   #4 (permalink)
Getting a set of springs from racetech wont be any worse with a passenger than the stocker. The stock spring gets 'stiffer' as you go through the travel of it, so unless you're riding with a passenger more often than riding solo, it'd still be beneficial to get a proper spring for your weight and riding style. Check out RaceTech's website, they have a spring calculator (you put in your weight and riding style) that will let you know what weight spring you need.
Their website is difficult to navigate, but start here:
http://old.racetech.com/evalving/menu/searchstreet.asp
Look for the link for the calculator, it says Custom Fork and Shock Spring Calculation and Available Rates
Should be HERE.
Every shock spring for the 675 is around $100, fork springs are about the same. Even without the valving the difference is noticeable even on the street.
Old 07-30-2009, 12:50 PM   #5 (permalink)
Favourite Bike: '06 675 Track Tool
TripleThreat's Avatar
Other Motorcycle: '03 KTM 640 Adventure
The stock rear spring on the 675 is not a rising rate spring. The Daytona has a rising rate linkage. Changing the spring will not change this. But, having the right spring for your weight is still a good idea.
NESBA "A" #719
On the Road Less Traveled...
...You Always Meet More Interesting People
TripleThreat is offline   Reply With Quote
Old 07-30-2009, 07:09 PM   #6 (permalink)
Have you reminded me of this before? For some reason I feel like I've been embarassed over this subject before... if I remember right, I went down fighting last time, holding on to my 'guns' that the spring was 'INDEED' a rising rate, and ended up getting schooled.
I think this time I'll try to skip that part and just say that 'to my knowledge', the stock rear spring is a rising rate spring. I may be wrong (and most likely am), but if I am, that's all the more reason to get a correct spring.
Old 07-30-2009, 08:03 PM   #7 (permalink)
jklnhd's Avatar
Well, whatevers back there, thanks for the info again
Checkin it out now. They're actually tellin me to go down from stock rate. A lot, actually lower than the lowest they got (yes, I see it says go with the closest).
Hi-Frequency Response Race Rebound Gold Valve < Not really sure why I need this, but it sounds badass.
Old 08-07-2009, 03:24 AM   #8 (permalink)
Favourite Bike: Daytona 675
Originally Posted by jklnhd View Post
...I get how to adjust it, but where should it be (stock)?
I'm trying to get everything back to factory looks/settings...
Stock settings for spring preload is 5 threads showing above the spring collars.
The OEM spring was measured to about 12.4 N/mm by a member on t675.net, linear. Racetechs calculator seems to suggest too soft spring, most people as well as the aftermarket shock companys choose 1 - 2 steps harder springs compared to the racetech recommendations.
As an example, I'm about 90-95 kg in gear and have an 11 N/mm spring fitted on my WP reduced with about 5% by custom linkage plates.
So for the stocker at my weight, I would go for a spring stiffnes of about 10 N/mm. My bike is used a lot on the track, but is also ran on the bumpy back roads of my countryside.
A rough estimate for the SAG when dialing the suspension in would be 25-30 mm for the rear and 30-35 front.
Good luck with Your modifications
roffe_s is offline   Reply With Quote
Old 08-07-2009, 07:36 PM   #9 (permalink)
jklnhd's Avatar
Sweet deal, thanks
I've been playing with the settings except for rear preload (don't have the tool). Still a little soft in the rear.
Old 08-13-2009, 05:22 AM   #10 (permalink)
Most of us start with the preload to set the bike geometry, then syncronize the rebound and compression settings front and rear.
FYI - Here is a good video of Dave Moss, setting up a Gixx.
Good luck with Your tuning
Sweet deal, thanks
Adjust rear preload? 97TB Club Cafe' 8 05-27-2009 08:44 AM
Rear Shock Preload. Limey Speed Triple Forum 3 12-23-2006 08:18 PM
rear preload hinkleyboy Triumph SuperSports 10 01-27-2006 03:59 PM
'05 S3 rear preload Martin_R Speed Triple Forum 1 05-22-2005 03:30 AM
Rear Preload SP3inAZ Speed Triple Forum 9 06-23-2004 08:57 AM
