Coil leads - What side for what color - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismHonda Powersports Motorcycle.comMotorcycle.com Classifieds!New Bonneville
Old 04-23-2005, 05:22 PM   #1 (permalink)
I'm working on a Daytona 1200. Need to know what coil the yellow with blue stripe goes on. I believe it is the one for the 2-3 cylinder, but want to make sure. I know that the red wire is on the right side of each coil (while you sit on the bike and look at them), I need to know which coil the yellow wire goes on.
I am not getting any fire to the bike and this is one of my process of eliminations.
Thanks
Lurch is offline   Reply With Quote
Old 04-23-2005, 05:22 PM   #2 (permalink)
Thanks
Old 04-23-2005, 09:28 PM   #3 (permalink)
Bret
Facing front:
Left side coil - green wire far left, red wire right cylinders 1 & 4
Right side coil - red wire left, yellow/green wire far right - cylinders 2 & 3.
Let me know if this fixes the problem.
Old 04-23-2005, 09:28 PM   #4 (permalink)
Bret
Facing front:
Old 04-23-2005, 09:53 PM   #5 (permalink)
Thanks for the input. Are you sure on the right side coil that the red wire is on the left side and not the right? The red wire is a common circuit and on all my coils the red is always on the right and the multi colored on the left.
I think it might be the coils themselves though. The owner remarked that the bike would sputter and shut off with him. I also suspect the ignition coil, but it has a closed circuit as of now.
Thanks for your help.
Old 04-23-2005, 09:53 PM   #6 (permalink)
Old 04-24-2005, 02:27 PM   #7 (permalink)
Bret
Lurch - the wires on my coils are as I stated in my previous email. I made a diagram when I removed them and it has always run just fine. The red is probably common as you say.
Are you sure the plug leads are hooked up correctly?
That is - left side coil, left output goes to #1 and right output goes to #4, right side coil left output goes to #3 and right side output goes to #2.
Obviously if you suspect a coil you can swap sides and try to eliminate the bad one....and also assuming all the gounds are clean and tight.
Old 04-24-2005, 02:27 PM   #8 (permalink)
Bret
Old 04-24-2005, 08:36 PM   #9 (permalink)
Yeah the leads are fine.
I would like to know if there is a way to test them. I realize I can put different one's on and try that, I just don't have extra coils to experiment with. My trident uses single out put coils, rahter than dual. I wonder how I could go about checking the signal coming into the coil?
Thanks for all your help.
Old 04-24-2005, 08:36 PM   #10 (permalink)
HT leads? vigneron Hinckley Classic Triples 2 05-06-2007 04:44 PM
removing color panels from the side hardbags sodapop Sprint Forum 7 03-30-2007 02:23 AM
sixty8 color matching side covers 10860 Twins Talk 10 10-13-2006 04:46 AM
Coil voltage and coil oil? kawtoy Classic, Vintage & Veteran 6 07-13-2006 11:35 AM
Color options...anyone ever trade tanks or buy a new one in the color they like? dazco Twins Talk 8 06-25-2005 12:00 PM
