Chain adjustment question - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 10-31-2008, 12:50 AM   #1 (permalink)
Favourite Bike: D955i CE
Erickex's Avatar
I am at my first chain adjustment on an 02 Daytona. I also have a 17 tooth front sprocket I want to put on. It is the CE so it has the SSSA. I figure the only way that cranking that wheel will tighten the chain is if there is an offset hole that the axel rides in inside the hub. I also read somewhere that adjusting the chain affects the ride height.
Does anyone know if 1) I need to drop a link in the chain to lose a tooth on the front sprocket and 2)if I can crank it forward so the hole drops down to lower the seat height rather than raise it? Thanks in advance for any help.
Erickex is offline   Reply With Quote
Old 11-02-2008, 09:14 PM   #2 (permalink)
Well i dont think the ride hieght will change, nothing you could notice, and if your changing sprockets its best to do both and a new chain, now i might add that it is preffered to change chain with sprockets not required if the sprockets are ok. As to the length i can only say i run the 17 tooth around the city and for the long trips i swap back to the 18, mind you it is a new 18 not the original, of course with the change back (2nd time) i have not changed the chain and have been running the same chain length, it has shortened the wheel base from the original 18 tooth front, but i kinda like it a little shorter, gives me more weight over it and the front gives more feed back, but thats just me, not saying its right.
Reaper is offline   Reply With Quote
Chain adjustment? My chain is too slack, cant adjust. roadkill Speed Triple Forum 12 06-17-2010 05:30 PM
Chain adjustment after suspension adjustment? Mochissmo Speed Triple Forum 1 10-13-2008 10:33 PM
Chain Adjustment question Trophy 5 10-09-2007 07:18 PM
Chain adjustment question stu Sprint Forum 5 09-26-2007 11:06 PM
06 ST chain adjustment question...... KevyKev Sprint Forum 4 10-31-2006 04:58 PM
