955 CE with electrical problems
Can any of the knowledgable folk here help me with this problem....
My CE died on the weekend - instrument cluster failed, lights failed, engine failed, unable to restart (solenoid chatter).
Back home - on the battery tender overnight.
Noticed that the Main Fuse (#3 30A) is melted in place, but still passes current.
Next Day
Checked voltages:
Ignition Off
12.2v at battery
Between 0 and 1v between red and black wires on Regulator/Rectifier - the reading never stabilised at all
Ignition On
11.85v at battery initially, but dropping .01v every 2 seconds or so.
.01v (steady) between red and black wires on Regulator/Rectifier
Running
11.49v at battery
.8v (steady) between red and black wires on Regulator/Rectifier
No shorts between Yellows and Red/Blacks from Regulator/Rectifier
I haven't got to the Stator yet, (got to work out where it is first!), but the dropping voltage with the ignition on alarmed me - it seemed to be dropping very quickly?
History of bike - I've had electrical trouble with it for the last couple of years - slow cranking, sometimes didn't start when hot, battery drained etc, and over that time I've had the R/R replaced, battery replaced, and most recently bought a battery tender and did the wiring mod as posted by ZAM70 (although haven't run heavy gauge wire to ground block from the battery, and did remove fuse #2 in favour of the new inline fuse). I thought this had solved everything - had 13.75v at battery when running, smooth response, strong starting etc, and it has been a good run for a few months. But now this.......
I'm thinking that something is obviously stuffed at present (RR?), but also that there must be something underlying all this that hasn't been resolved.
Any clues around what I should do next, before I end up paying the dealer more $ to scratch his head?
