Header Pipes Daytona 1200 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 04-19-2005, 08:38 AM   #1 (permalink)
Favourite Bike: Thunderbird (2003)
roy005's Avatar
Other Motorcycle: Daytona 1200 (1996)
Extra Motorcycle: Scrambler (2006)
I got the bright idea to have my header pipes on the Daytona 1200 Jet Hot coated (flat black) before they deteriorate any further. The Haynes manual says to drain the oil and move the oil cooler out of the way. Only problem is I just changed the oil a few hundred miles ago. So I hate to do it (BTW- I use BMW 15w-50 oil).
Anyone know if you can remove the headers without draining the oil? Will I have enough room to work by just loosening the oil cooler support bracket? Thanks. :???:
Ride, Eat, Sleep, Repeat....
roy005 is offline   Reply With Quote
Old 04-19-2005, 08:38 AM   #2 (permalink)
roy005's Avatar
Old 04-19-2005, 09:55 AM   #3 (permalink)
Favourite Bike: Daytona Super III
Hinckley's Avatar
Other Motorcycle: Suzuki GT750
I know it can be done on the 900. I losened the oil cooler bracket as you stated and the header came right off, no problem.
UFOB #56
The Mighty Buffalo
Hinckley is offline   Reply With Quote
Old 04-19-2005, 09:55 AM   #4 (permalink)
Hinckley's Avatar
UFOB #56
The Mighty Buffalo
Old 04-20-2005, 07:20 PM   #5 (permalink)
roy005's Avatar
Thanks Hinckley. I'll give it a try first chance I get.
Header Pipes Only? RANCAM Twins Technical Talk 6 08-27-2008 01:25 PM
Where can i get speedtriple header pipes???????? kevf Speed Triple Forum 5 12-28-2006 08:38 PM
Header Pipes Stampy Speed Triple Forum 11 06-23-2006 06:02 AM
Painting header pipes THRUXGIRL Twins Talk 2 04-30-2006 05:57 PM
Anyone make Aftermarket header pipes 02 S3? kevf Speed Triple Forum 8 04-08-2006 03:51 PM
