When should the coolant fan kick in - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleSportbikeTrackGearOntario Tourism
Old 10-08-2008, 11:33 AM   #1 (permalink)
Favourite Bike: my daytona 900
Hi All
My first post here
I have a 1993 daytona 900 which I absolutely love but recently something strange has been going on.
I ve had it for over a year now and when i first got it the temp gauge was normally on the very bottom line and then if i got in traffic it went half way up the gauge before the fan kicked in.
Then all of a sudden it started running with the gauge on the middle line (Near the bottom) which I am told is where it should have always been but when I get in heavy traffic the gauge goes to within about 2mm of the red before the fan kicks in.
I ve changed the coolant, cleaned the radiator of mud and stuff which has made no difference.
I recently took the bike on a 250mile round trip with no problems (Although I didnt hit any traffic) with the gauge staying on the midle line through out.
I should add that the bike doesnt go into the red when im in heavy traffic and as soon as I get out of traffic the temp drops again, just makes me feel uncomfortable seeing a temp gauge that near the red.
Can anyone tell me if this is normal, where the gauge should be or should I be getting worried about it, also is it possible to change when the fan kicks in? say nearer the middle of the gauge
thanks
Gibbo
gibbo1715 is offline   Reply With Quote
Old 10-08-2008, 05:50 PM   #2 (permalink)
DEcosse's Avatar
The temp indication & fan are two completely isolated functions with different sensors.
The fan is controlled by a thermoswitch in the radiator - when the temp exceeds the switch point, it turns on the fan until it cools and resets the switch.
I suspect from your description there is nothing wrong - or different - with your fan switch - the fan will typically not operate until quite close to boiling.
And it appears that situation is unchanged with where it operates, it is more your temp indication that has changed. This could have been down to improperly bled system (assuming your temp sensor itself wasn't replaced) and not indicating normal temperature. That appears to be remedied now as gauge is operating in the 'normal' zone.
I think you're just fine.
Fan ThermoSwitch is item 28
Coolant Temp Sensor is item 17
T'Rat.net BOTM November 2009
Old 10-08-2008, 05:54 PM   #3 (permalink)
Favourite Bike: 02 D955i
drakewn's Avatar
If your bike was truly overheating, you should notice a lot more heat coming off the engine.
drakewn is offline   Reply With Quote
Old 10-08-2008, 07:10 PM   #4 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
Gibbo, The info I have is fan on at F217 and off at F212.
My '98 T595's fan switchs on at slightly different needle positions on the unmarked temp gauge. Generally it's half way between the second and third hash mark. I'd marked the 'fan on' position on the temp gauge with a felt tipped pen when I first bought the bike while it sat running in the garage. The fan start point can be off by three needle widths either side of the mark on the road.
Usually it runs a couple of needle widths above the second hash mark out of heavy traffic. Reads like your '93 is doing just fine.
Brad
Old 10-09-2008, 04:16 PM   #5 (permalink)
All
Can i just say thanks for all your replys, i think its fine and i was just worrying about nothing, probably because i love my bike so much
gibbo
Started on third kick!. . . MORRISTHECAT Classic, Vintage & Veteran 2 03-28-2008 12:20 AM
Coolant stains on coolant hose? moyster Speed Triple Forum 3 10-09-2007 12:02 PM
Brown coolant??? Coolant change?? Suncoast Sprint Forum 8 02-05-2007 12:51 PM
Thought you would all get a kick out of this. Hotmailjerk Speed Triple Forum 16 06-06-2006 07:10 PM
Flushing 01 coolant, no manual? coolant bubbles after use! speedtripleride Speed Triple Forum 1 05-21-2006 12:53 PM
