Daytona 1200 specs - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Honda PowersportsSportbikeTrackGear
Old 10-05-2008, 05:04 AM   #1 (permalink)
Favourite Bike: '99 Daytona 1200 SE
tritonwow's Avatar
Other Motorcycle: '95 Super IV
Extra Motorcycle: '67 eNorton project
Daytona 1200 specs
Weights (in pounds):
??.?? OEM front fender
0.55 Super III carbon front fender (with speedocable keep)
1.60 OEM rear hugger
?.?? Super III carbon rear hugger (I just need to take it off to weigh)
6.80 OEM seat with cowl
4.20 OEM tail section (both sides and center)
7.00 OEM lower fairing (pair with inner panels)
3.90 OEM upper fairing (with aftermarket flush blinkers and windscreen)
0.80 OEM inner upper panels (4 pieces)
2.10 OEM mirrors (pair)
14.90 OEM gas tank (with gas cap, mnting bracket, fuel sensor, fuel tap)
24.75 OEM mufflers (pair)
80.00 frame (both main and sub)
http://www.triumphrat.net/memberalbu.../15516/cat/500
I am a volunteer, knowing well the hazards of my profession.
tritonwow is offline   Reply With Quote
Old 10-05-2008, 05:05 AM   #2 (permalink)
tritonwow's Avatar
Measurements (in mm):
88-88-88 OEM carb spacing
36 OEM carb inlet inner diameter
42 OEM carb inlet outer diameter
Old 10-05-2008, 05:07 AM   #3 (permalink)
tritonwow's Avatar
Just in case
Ok, So anyone with something not in the manual post up and I'll add it to one of these front three posts.
Keep the shiny side up!
Old 10-05-2008, 11:01 AM   #4 (permalink)
Favourite Bike: 97 Trophy 900
andrewb's Avatar
Do you have a weight on the stock cans and front/rear wheel assembly's?
I have front rotor weight for you on Tuesday!
andrewb is offline   Reply With Quote
Old 10-05-2008, 06:25 PM   #5 (permalink)
tritonwow's Avatar
Cool. I didn't weigh the wheels but will when I need to change tires (that won't be for awhile though) If someone else has the weights (or any info to add to the list) just post up and I'll add it to one of the first postings.
Old 10-12-2008, 01:26 AM   #6 (permalink)
well...
What's the total weight of your beast? By the way, are you stock carbon fiber cans real carbon fiber or did Triumph put "fake" carbon fiber on them?
SC SuperIII is offline   Reply With Quote
Old 10-12-2008, 03:58 AM   #7 (permalink)
tritonwow's Avatar
I'm not sure of the total weight but it's heavy (a shocker moving back and forth to the Bonne). I'll be moving again so I might try to find the scales around here and weigh it.
The carbon cans I have must be aftermarket but I can't find a marking anywhere on them as to who made them. They are true CF and the weight can attest to it.
My OEM cans are not CF nor do they have CF wrapping... straight up black paint. These are not mounted on my bike (but I keep them because when I live in Japan I have to have all OEM equipment on the bike to be able to pass inspection).
Trophy 1200 1993 - Carburetor specs pllorca Trophy 0 07-29-2008 07:36 PM
does anyone have any jetting specs for a daytona 1200 se adepackett Daytona Deliberations 0 08-31-2007 03:36 PM
daytona specs djlnz Trophy 3 08-28-2007 06:07 AM
1200 Daytona vs. 1200 Trophy? ElJugador Triumph, Models & Dealers 1 07-13-2006 01:25 PM
Daytona Caliper Specs MickMaguire Daytona Deliberations 9 06-14-2003 07:38 AM
