955 daytona 955 speed triple - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-13-2005, 07:25 PM   #1 (permalink)
blkse04
Hey guys is there any motor differnce between the 955 daytona and the 955 speed triple... Dynojet has way more maps for the speed triple than the daytona.. so i was wondering if the motors where the same then y couldnt i use the maps....thanks John
Old 04-13-2005, 08:20 PM   #2 (permalink)
Somebody out there will know more about this than me, but the Daytona's got a few more tweaks to some internal parts to give it a few more horses and top end speed...
dml955i is offline   Reply With Quote
Old 04-13-2005, 11:30 PM   #3 (permalink)
I believe the differance is cam profile,fuel injection and gearing (trans).,,,,John
RIDE IT LIKE YOU STOLE IT!!!!!!!
EUROTWINS is offline   Reply With Quote
Old 04-14-2005, 04:18 AM   #4 (permalink)
blkse04
well i guess that answers that.......remapping using that map wouldnt be good.......thanks john
Old 04-14-2005, 11:00 AM   #5 (permalink)
Favourite Bike: 2003 Triumph Speed Triple
Your best bet is either a PCIII or Tuneboy and dyno tuning from scratch to clean up your map. I did it with my S3 and OMG is it smoother with more even power throughout the powerband, even moreso than before.
Old 04-14-2005, 02:17 PM   #6 (permalink)
I run a Power Commander and had it tuned on a dyno. My Daytona runs well. I like the Power Commander as I believe it can get the most from the motor however it much be tuned by an experience tech on a dyno...John
Old 04-16-2005, 05:14 AM   #7 (permalink)
blkse04
Hey,did u use you power commander b4 you had your bike dyno tuned? if so did u notice a differnce? thanks John
Old 04-17-2005, 12:24 AM   #8 (permalink)
No, they installed the PC before they put it on the dyno, But my seat of the pants says it made a huge differance....John
Old 04-17-2005, 08:04 PM   #9 (permalink)
Yeah, having the air/fuel ratios smoothed out makes a huge difference with roll-on power and throttle response. Even if the resultant max power isn't much higher, the rideability difference is quite notable.
Old 04-18-2005, 06:22 AM   #10 (permalink)
Favourite Bike: 2002 RS
Stlakid's Avatar
Other Motorcycle: 1981 Honda CB-900F/w full Greer Fairing (#0001!)
Daytona's.......
Cams are different. Forged pistons. Shot peened rods. Nicasil coated aluminum liners. Valve sizes may be different, but possibly not all years. (not sure on that one.
Speed Triple......
Cast pistons. Iron cylinder liners.
My Photo Album
Stlakid is offline   Reply With Quote
speed triple 955 Fridgehq T3 Sport / Touring Forum 10 07-07-2007 02:19 PM
Speed triple 955 Fridgehq RAT - United Kingdom 4 07-06-2007 03:04 PM
955/speed triple Centerstand!!! peterk Daytona Deliberations 8 06-19-2007 11:50 PM
'06 Speed Triple USD forks onto Daytona 955? trojan7horse Daytona Deliberations 11 08-17-2006 12:07 AM
used 955 engine needed for an '03 Speed Triple (Daytona) Daytona Deliberations 0 09-15-2004 01:07 PM
