95 daytona problems.. help! - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 09-24-2008, 03:44 AM   #1 (permalink)
Favourite Bike: 95 Daytona 1200
Unhappy 95 daytona problems.. help!
hi all new to the forums and to motorcycles in general...i picked up a 95 daytona yesterday and upon first ride of 60 miles or so the bike runs great...took it out again later on and maybe 15 mins into ride the bike starts to act like its running out of gas, losses all top end then low and then just dies.. bike wouldnt start for a good while.. but let sit and then started up and proceded to die again later...let it sit overnight same scenario...what could be the problem? also its burning through fuel and i believe im getting something close to 20 miles to the gallon... any ideas?
guitarsavior is offline   Reply With Quote
Old 09-24-2008, 04:32 AM   #2 (permalink)
Favourite Bike: '99 Daytona 1200 SE
tritonwow's Avatar
Other Motorcycle: '95 Super IV
Extra Motorcycle: '67 eNorton project
Welcome. A few helpful pointers;
1. You would most likely get more responses if you post in the Sport and Touring>T3 Sport / Touring forum. Your bike is a T3.
2. There is a search feature up near the top of the page. Type in a few key words related to your inquiry and hit search. You might find what you're looking for. Once you get familar with the search funtion you can refine it with an advanced search. Some examples of what you might find:
http://www.triumphrat.net/daytona-de...-96-d1200.html
http://www.triumphrat.net/t3-sport-t...ride-home.html
http://www.triumphrat.net/t3-sport-t...l-related.html
There are also "stickys" at the top of most forums and the T3 has a FAQ sticky.
3. I didn't find what I was looking for when I just searched but if you search my name and all my posts you might find something I wrote (along with others) to newcomers about basic sequential troubleshooting dependent on your issue.
For you I'd check fuel delivery first.
Check to see if you have enough gas.
Try using "Prime" position on your petcock (vs On or RES). The petcock is vacuum operated but when on "Prime" feeds the carbs via gravity (lets you know if maybe the petcock is bad). I just reread your post; If your petcock is already on "Prime" you may be flooding the carbs.
Check all your fuel and vacuum lines to ensure they are not cracked, kinked, missing, etc. Bottom line; eliminate fuel issues as the source of your troubles then move to the next step (Which should be ignition but I don't have a manual in front of me.)
4. T3 known issues (not all related to your problem and not meant to scare you off.) These issues are covered extensivley in the T3 forum and I'm sure I'm missing a few:
Vacuum petcock
misrouted fuel and vacuum lines
bad coils
sprag clutch
alternator bolt
Good luck with your quest because these era Triumph bikes ROCK!
I forgot to add; since I own a 95 Daytona 1200 I frequently search the Daytona Deliberations, T3, AND Trophy forums
http://www.triumphrat.net/memberalbu.../15516/cat/500
I am a volunteer, knowing well the hazards of my profession.
tritonwow is offline   Reply With Quote
Old 09-24-2008, 02:46 PM   #3 (permalink)
thank you very much for pointing me in the right direction... i will start with your suggestions right away.. and i do agree these bike do rock!
98 Daytona problems reddaytona595 Daytona Deliberations 1 09-02-2008 09:00 PM
Daytona Problems.....Please Help JHans15 Daytona Deliberations 11 03-26-2008 11:39 AM
Daytona 650 Problems wrx02 Triumph SuperSports 7 10-01-2007 01:43 AM
'04 Daytona problems starting???? 955iLimited Maintenance & Workshop Talk 2 09-18-2006 11:19 PM
95 Daytona - still having problems Lurch Daytona Deliberations 11 05-18-2005 05:14 PM
