Daytona 1200 time clock fitting - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearHonda Powersports Motorcycle.comNew BonnevilleOntario Tourism
Old 08-27-2008, 12:35 PM   #1 (permalink)
Favourite Bike: Daytona 1200 SE
DLBass's Avatar
Other Motorcycle: K1200LT SE
Extra Motorcycle: XS650C
I wasn't sure where to post this, so I've put it here as well as the Sport Touring forum
I'm sure someone out there has done this before, so here is the question
Is the digital time clock from the Sprint ST a plug and play item into the loom of the Daytona 1200? I'm sure I read somewhere that the modular design extended as far as the looms on these bikes, so will I find a plug for the clock if I start digging?
I think I will have to fit a volt meter into the other side of the fairing panels to balance things up a bit, but I just hate riding without a clock to check.
Guess I'll never be a wild hog Oh well .....
David
When you Triumph, remember it's the result of putting a little umph in when you try. Don't cheat yourself with less.
DLBass is offline   Reply With Quote
Old 08-28-2008, 10:05 AM   #2 (permalink)
Favourite Bike: 1999 Daytona 1200SE
JohnD's Avatar
Other Motorcycle: '08 Kawasaki Concours 14
Extra Motorcycle: a.k.a. GTR 1400
Check out DaytonaCharlie
This is what DaytonaCharlie has done with his clocks. Maybe you want something like this. If so, contact him regarding any questions.
This is a web address from DaytonCharlie's photo album showing his clocks.
http://www.triumphrat.net/memberalbu...t/3/ppuser/171
While you're at it, you should check out the Kawasaki girl poster. Out-of-the-past HOT!
JohnD is offline   Reply With Quote
Old 08-29-2008, 07:08 AM   #3 (permalink)
Favourite Bike: Daytona Super III
Hinckley's Avatar
Other Motorcycle: Suzuki GT750
Yes, the clock from the Sprint will plug right into one of the loose connectors in the harness. I mounted the clock in the black filler that is on the inside of the side fairing.
Next, I'd like to fit up the fuel gauge from the Trophy.
UFOB #56
The Mighty Buffalo
Hinckley is offline   Reply With Quote
Old 08-29-2008, 08:30 AM   #4 (permalink)
Favourite Bike: My '04 Sprint-ona
RexxyPup's Avatar
Other Motorcycle: Want a 675
Extra Motorcycle: I wish!
Interchangability
Hi,
I'm not sure how relevent to your situation this comment is, but a cautionary note....
Some of the things on the bikes are dependent upon ECU etc.
My example is that I have an 04 ST that I recently fitted with an 05 Daytona engine.
As an ST with the ST tune in the ecu the fuel gauge worked.
As an ST with the Daytona tune in the ecu, the fuel gauge doesn't work. The daytona doesn't have a fuel gauge, therefore the tune does not tell the ecu to transmit the signal coming from the sender unit.
Like I said, this may not be specific to your bike(s) but it is worth bearing in mind.
Personally I'm going to remove the fuel gauge and replace it with a volt meter instead!
Rexx
WARNING:! Low flying Sprint-ona ahead!
Old Albums
New Albums
RexxyPup is offline   Reply With Quote
Old 08-29-2008, 05:32 PM   #5 (permalink)
Hinckley's Avatar
Nope. Not in this case. Back when the T3 range was in production, many of the components were modular. Triumph did this to keep production costs low at a time when they were unsure of the success of the revived brand. Many of the parts are interchangeable from bike to bike.
UFOB #56
The Mighty Buffalo
Old 08-30-2008, 11:36 AM   #6 (permalink)
DLBass's Avatar
Thanks for your input.
Hinkley, I take it that to fit the fuel guage from the Trophy I would need the sender etc. and that it would all fit into my existing tank, so another plug and play.
David
Old 08-31-2008, 12:28 AM   #7 (permalink)
Hinckley's Avatar
I have not done this mod yet. I have the gauge but not the sender.
There is another connector dangling near where the sender would go, so I am assuming ......
UFOB #56
The Mighty Buffalo
Clock fitting for a Daytona 1200 DLBass T3 Sport / Touring Forum 4 08-30-2008 11:43 AM
Datatool S4 fitting on Daytona 675? Dillinger Maintenance & Workshop Talk 0 05-22-2008 04:52 AM
Fitting Motrax Little Ben clock onto Bonnie barneys Twins Technical Talk 6 09-21-2007 08:29 PM
Changed clock time and now RS temp reads Deg F not Deg C GreenGoblin Sprint Forum 5 09-20-2007 08:56 PM
1200 Daytona vs. 1200 Trophy? ElJugador Triumph, Models & Dealers 1 07-13-2006 01:25 PM
