wobbling fuel tank
I was messing around with my just bought '05 daytona 955i and I took the fuel tank off to look at the airbox and stuff but now i feel like an idiot. When i'm trying to bolt the fuel tank back on it won't sit correctly onto the frame. It seems like when I put the tank retention rubber under the tank on the front mount, the rubber jacks the tank up too high and the two support rubbers on the underside of the tank can't contact the frame at the same time, so the tank wobbles back and forth. Am I missing something here. Is there a bolt or screw I'm forgetting about? Or did some type of spacer fall out when i lifted the tank up. I think I have the rear tank mount correctly placed. Just the one screw, going through the clamp plate, the cut length mount and then the rubber rear mount pad. Thanks for any help.
"Me and my friends have been too busy bathing off the southern coast of St. Barts with spider monkeys for the past two weeks, tripping on acid, changed our whole perspective on s***" - Hansel
