Trident-Exhausts.comAdvanstarMotorcycleShowsMotorcycle.com
Old 05-07-2008   #1 (permalink)
Muzzy Can on 02 Daytona
Pipe works fine with TOR tune. Slight flat spot between 6-7k.
Am going to get a tuneboy.
We got a used Muzzy Ti oval cannister and steel mid-pipe from a 04 ZX10R. From the photos, it looked like it may fit.
We measure the diameter of the Daytona header outlet and the diameter of the ZX10 Muzzy midpipe. It was almost spot on.
I was hoping that it would fit right off the bat but we quickly discovered that unless I wanted to have a pipe that looked like it came off the Munster's car, we would have to do some cutting.
We cut off the bend on the Muzzy mid-pipe right where it met the header of the Daytona.
We then cut 4 slots into the midpipe to be able to squeeze it down with the exhaust clamp.
A little Bronze perm-a-tex and have a nice tight seal.
There is plenty of room to adjust for final position. I like it tucked in and at a slight tilt.
Good luck,
Ed
Pinballer is offline   Reply With Quote
1969 daytona T100R to 2007 Daytona 675, new rider ezranz Daytona675 Forum 10 04-20-2008 03:33 PM
Daytona 675's run the Daytona 200 daytonacharlie Biker Hang-Out 2 03-11-2007 12:57 PM
Daytona 955i(1050?) or Daytona 675? qc415 Daytona Deliberations 19 12-05-2005 10:28 AM
2002 Daytona versus a 2003 Daytona? bssofro Daytona Deliberations 13 09-30-2004 04:23 PM
Diffrences on Sprint ST and Daytona -or- bags on Daytona? coldnight Modifications & Workshop Talk 1 07-23-2002 07:25 PM
