BikeBanditAdvanstarMotorcycleShowsShopTriumph.comMotorcycle.comTrident-Exhausts.com
Old 05-05-2008   #1 (permalink)
Newbie
Brake lever replacement 955i
Hi all,
Can somebody please tell me how to change a front brake lever on a 03 955i?
I snapped it on the weekend & am not sure about the procedure.
Thanks...Oz_trump
oz_trump is offline   Reply With Quote
Old 05-05-2008   #2 (permalink)
should be very simple. unscrew the bolt that runs through the lever, remove and take off the lever.
If you don't want to spring the $50+ for a triumph lever there are certain suzuki, kawi and yamaha brake levers that will fit the triumph master cylinder for well under $20
ROWYKO!
xactoman is offline   Reply With Quote
Old 05-05-2008   #3 (permalink)
Newbie
Thanks for that but what about the cable? How does the cable fit the lever? And the adjustment?
Old 05-06-2008   #4 (permalink)
Are we talking about the same thing? Front brake is hydraulic. There is no cable. Lever is just free-floating as it pushes against the master cylinder piston.
ROWYKO!
Old 05-06-2008   #5 (permalink)
Favorite Bike: Today - MV Agusta F4 312
fivehundo's Avatar
Other Motorcycle: Triumph Daytona CE
Extra Motorcycle: Husqvarna SMR 450
Very easy...
If you buy Pazzo levers, they come with instructions...
"The Father wove the skein of your life a long time ago. Go and hide in a hole if you wish, but you won't live one instant longer. Your fate is fixed. Fear profits a man nothing." Herger the Joyous
fivehundo is online now   Reply With Quote
Correct position for brake lever on rear conical brake johnquinnell Classic, Vintage & Veteran 11 03-09-2007 03:42 PM
T140 replacement front brake lever/cylinder yellowtrumpet Club Cafe 6 11-07-2006 12:19 PM
NEED 955i shift lever nyburner Daytona Deliberations 3 08-14-2006 11:46 PM
NEED 955i shift lever nyburner Sprint Forum 0 08-13-2006 01:56 PM
NEED 955i shift lever nyburner Speed Triple Forum 0 08-13-2006 01:50 PM
