should be very simple. unscrew the bolt that runs through the lever, remove and take off the lever.
If you don't want to spring the $50+ for a triumph lever there are certain suzuki, kawi and yamaha brake levers that will fit the triumph master cylinder for well under $20
ROWYKO!
