There are only 2 tunes available for your bike - std & after-market exhaust.
There are 4 tunes total for your model year, however 2 are for ones fitted with SAI and two for bikes without.
I would suggest you should have your dealer install the one for after-market exhaust - so 10179 or 10181 depending on whether you have SAI or not.
Did the bike run OK with the tune that was installed when you bought it? Did it have after-market exhaust then or did you add this afterwards? What drove you to have new (TORS) tune installed - because it was running badly, or because you felt you should after installing slip-on?
Sounds to me like if it was running somewhat decent before the dealer has installed incorrect tunes - both times possibly!
Edit - from
this post you said bike was running great then you removed the baffle from the exhaust - did things go South immediately after that, or was it still running OK, but you felt (on advice from me among others!) that you should install the TORS tune?
