Old 04-21-2008   #1 (permalink)
Acumen/any gear indicator
Hi, I just spoke with a guy from acumen who informed me that they had a fair amount of problems with the gear indicator on the 955i's as the signal noise from the alternator is too strong. This was down to the individual bike, so some would have problems, others worked fine. I could risk it, but I'm looking at £100 for the unit and loom, so I'm having an ask around first!
Has anyone experienced anything like this, and does anyone know of an alternative gear indicator that might not suffer from this (eg, there used to be an indicator that replaced the neutral sensor in the gearbox for a sensor that would sense each gear) or perhaps a solution to fixing a noisy alternator?
Thanks in advance.
<img src = "http://www.frenchgeek.com/images/955ism3.jpg">
loco is offline   Reply With Quote
Old 04-21-2008   #2 (permalink)
DEcosse's Avatar
Other Motorcycle: Suzuki TL1000S
Never heard of the noisy alternator thing!!
I have the Acumen - I previously had it installed on my T509 (mech speedo) using an auxiliary speed sender; since I retrofit in the Daytona motor with wiring harness etc, I now use the OEM front sender to trigger off.
One issue with this is the update rate, especially in the lower gears, due to the slow pulse count off the OEM sender per wheel revolution. Otherwise it works fine. Any other indicator will suffer from same on the Triumph. The later 1050 bikes with transmission sender are probably better.
GSXR 1000 Front End Swap
Old 04-21-2008   #3 (permalink)
Thanks for the reply.
Has anyone used one of the plug-in looms for a 2005 or beyond 955i? They know that it will fit a 2004, but they're unsure if the wiring layout changed with the '05 955i and later.
Thanks again.
Acumen gear indicator? welshrob Speed Triple Forum 14 11-28-2007 07:45 AM
Gear indicator, why not? trumppa Speed Triple Forum 20 08-23-2006 04:52 PM
Acumen DG8 - Digital Gear Indicator ? PaulBerg Tiger Mods & Bolt-Ons 2 05-02-2005 03:35 PM
Acumen digi 8 Gear selection indicator Modifications & Workshop Talk 0 05-24-2004 02:28 AM
Acumen Digital Gear Indicator - how to connect to Daytona 600?? Modifications & Workshop Talk 0 03-28-2004 06:36 AM
